Old 03-14-2019, 11:27 AM
kjowen's Avatar
kjowen kjowen is offline
Default Suggestions to finish this off?
RV-8, Right Elevator.
I am fitting everything prior to final assembly of the component.
I still need a little more sanding on the E-612 fiberglass tip as it sits proud of the weight.
Just wondering what others have done in this area to finish off the forward edge?
Maybe a flox mixture to smooth over the lead counter weight?
Ken Owen
Marietta, GA
RV-10, N471BG
RV- 8, N297DW, (sold)
RV- 8, Build in progress
VAF 2021 Donation
Old 03-14-2019, 11:36 AM
Raymo's Avatar
Raymo Raymo is offline
A little epoxy and micro will do the job. Flox will not sand smooth.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 03-14-2019, 11:46 AM
kjowen's Avatar
Default Sorry... used the wrong term...
Micro balloons is what I meant since this area is non-structural and is just for filling and smoothing the surface. thanks!
Ken Owen
Marietta, GA
RV-10, N471BG
VAF 2021 Donation
Old 03-14-2019, 12:56 PM
One thing to consider is if you want the joint to disappear or not. My experience on boats is to make it go away, it needs glass over the joint or it will crack. You could fill up to it and tool or sand a joint. Try it and see how it looks. Worst case, sand it off and do it again.
Maybe make a mock up and try it first?
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 03-14-2019, 05:28 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Micro to fill the voids, sand then a couple of bids of glass. Some micro over the glass to fair it in.
Without the glass the micro will eventually crack and you will see it in the paint.
Carl
Old 03-14-2019, 11:15 PM
climberrn's Avatar
climberrn climberrn is offline
Micro has worked fine for me for 500 hours. No cracks yet. Did use red locktite on those bolts. Don’t want those things backing out, ever....
Also, might want to consider some strategically placed Nutplates near the forward edge of the counterweight. Really convenient for adding weight for balancing after paint.
Joel
N626JA
RV-7A at CXP
Flying!
Old 03-15-2019, 07:49 PM
MIKE JG MIKE JG is offline
Ooh, that's a nice tip, adding that one to the collection of "things to do that are not in the plans".
Thanks!
-Mike G
Northeast Ohio
RV-8
Working on the HS
Builder #83203
VAF Dues Paid Monthly
My Build Log: https://eaabuilderslog.org/?blproject&proj=7YG4STHvs
Old 03-20-2019, 08:14 PM
kjowen's Avatar
Default Nutplates?
Can you elaborate?
Thanks!
Ken Owen
Marietta, GA
RV-10, N471BG
VAF 2021 Donation
Old 03-20-2019, 08:26 PM
wirejock's Avatar
wirejock wirejock is offline
Default Balance nut plates
Originally Posted by kjowen View Post
Can you elaborate?
Take a look at the rib. You'll see a tooling hole pretty close to the counterweight. Install a nutplate there. A 3/16" works for the hole size. A bolt can be installed with lead or tungsten washers for final balance.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 03-21-2019, 08:55 AM
DanH's Avatar
DanH DanH is offline
http://www.vansairforce.com/communit...7&postcount=25
With the lead present in this assembly, you can skip the core plate step. Just fill all around the edge, between the glass and the lead, cure, sand to shape, and add a few plies of glass fabric. It's pretty much what Carl said.
Dan Horton
RV-8 SS
Barrett IO-390
