don't use an oring. They are not appropriate for flare fittings. If you read the reviews at ACS, it appears this reducer is too big to fit most fittings. You need to either trim down the female side to fit (where it doesn't bottom out via the base) or install a new bulkhead reducer fitting to do the reduction.
Larry
