Go Back   VAF Forums > Model Specific > RV-14
Old 03-06-2019, 12:25 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Default Nose Wheel Breakout Force
Have any of you had to re-adjust the nose wheel breakout force after flying for a while?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 03-06-2019, 01:38 PM
Nova RV Nova RV is offline
Yes, mine went loosened up to 16lbs before I was finished with phase 1. Tightened back up to spec and I'll check it again before leaving for SNF.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 03-06-2019, 02:14 PM
rvbuilder2002's Avatar
Some loosening after gaining time in use is totally normal.
I usually recommend that people check it (regardless of RV model) after 30-40 hrs and then again at 100.
After 100 it usually doesn't change much.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 03-06-2019, 05:08 PM
mturnerb mturnerb is offline
My question is how often does the tightening after 30 and 100 hrs require drilling new holes for the cotter key? I got lucky the first time
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 03-06-2019, 05:39 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Don't be afraid to tighten a bit over specs. All of the Bellvile washers flatten out over time. If you feel even a slight vibration on taxi or landing, tighten immediatly. Do not lube the Bellville washers. They are supposed to rub against one another dry. Cheers.
Old 03-06-2019, 06:59 PM
bkervaski's Avatar
same here
Good to know!
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 03-06-2019, 08:48 PM
n982sx n982sx is offline
Have tightened twice now in 240 hours.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 03-07-2019, 11:09 AM
rleffler's Avatar
rleffler rleffler is offline
On my RV-10, I've had to tighten twice over the first three year period, each time requiring a new hole. It's been three years since the last time and the tension is holding every time I check it.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-07-2019, 11:49 AM
Bavafa Bavafa is offline
On My RV7A, I checked at each annual and never had to tighten it, though I had started a bit higher than recommended. I will be checking the 14A in the next few days to see if it needs any changes. So far, no shimming has been noticed.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 03-07-2019, 12:44 PM
Like all things RV, what I dread (drilling those new holes) will be no big deal but the thing that looks "easy" prospectively will be hard.
Turner Billingsley
