Old 03-04-2019, 05:27 AM
TomVal's Avatar
TomVal TomVal is offline
Default Vibration...What Time Zone is Your Prop In?
I recently installed a new Sensenich ground adjustable prop designed for my engine. On this engine the maximum / maximum continuous rpm is 3300. Vibration would start at 3180.
The fix was easy. I re-clocked the prop from EST to EDT and moved the prop ahead one position on the prop flange. Now off to find a shop that does dynamic balance.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
