  #11
Old 04-11-2019, 05:38 PM
rv7charlie rv7charlie is offline
I hope this isn't construed as splitting hairs, but I question Mel's blanket statement that simply changing a prop requires a return to phase 1. Unless the regs have changed, my understanding is that only a change of *type* (ex: fixed>c/s) triggers the requirement for phase 1.
Please correct me if I'm wrong.
Charlie
Old 04-11-2019, 05:50 PM
Mel's Avatar
Mel Mel is offline
Charlie
Any prop change requires a new phase I flight test program, unless it is the same diameter and pitch from the same manufacturer.
A major change is pretty much anything that will change the flight characteristics of the aircraft.
The difference of changing F/P to or from C/S requires that you submit a new 8130-6. This is to change the records in Oklahoma City.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-11-2019, 11:32 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
The LAA in the UK specify this test schedule for newly installed CS props.
You may want to use it as a basis for your testing.
