Old 02-26-2019, 02:05 PM
Steve Melton's Avatar
Default Whirlwind factory tour
I met Jim Rust at Whirlwind Propeller (KSEE) for a factory tour and he showed me his latest product in development, a new three blade constant speed, and said I could post a few pictures. Note how thin the blade is, that's good for performance. It seems they have invested in technology with a 5 axis mill that produces the hub in one setup for precision parts. My Whirlwind 200RV prop has performed flawlessly for 750 hrs and looks good.
Vibration survey on IO-390 RV-14
300 series on RV-8 O-360 light speed ignition
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 02-26-2019, 02:11 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Pics not showing
Did he mention what aircraft/engine they are building this new prop for?
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2020
Old 02-26-2019, 02:17 PM
RV series and similar.... and a version for RV-10.
Steve Melton
Cincinnati, OH
Old 02-26-2019, 02:24 PM
airguy's Avatar
airguy airguy is offline
Steve - I believe the Whirlwind 200RV prop (I have one also) is produced by Whirlwind Aviation out of Austinburg Ohio, http://www.whirlwindaviation.com/index.asp, not Whirlwind Propellors out of El Cajon, CA https://whirlwindpropellers.com/aircraft/
Nonetheless, it's pretty hardware.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 02-26-2019, 02:25 PM
this is where the blades come from for the 200RV.
Steve Melton
Cincinnati, OH
Old 02-26-2019, 03:03 PM
airguy's Avatar
That being the case then, if blades need to be refurbished, do we work with the Ohio group or the California group? Hub work and overhauls would be done out of Ohio with blades provided from California?
Old 02-26-2019, 05:02 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Jim Rust?s company in California Designs makes the raw blades and hubs. They ship the parts to Ohio where they are finished, assembled, and sold to customers. So basically, if you are dealing with a Constant Speed Whirlwind as a customer, you deal with Ohio.
I know the guys at both locations - good folks working hard to provide good products.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-27-2019, 11:25 AM
YellowPeril's Avatar
YellowPeril YellowPeril is offline
I purchased my WW 200C from Jim almost 17 years ago, and between working with him and the Ohio crew I'd recommend their props and service to anybody.
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
Old 02-27-2019, 04:22 PM
ppilotmike's Avatar
Default Weight & Cost Savings?
For the RV-10 CS Prop model, what is the savings over the 2-blade Hartzell from Vans (cost and weight)?
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 02-27-2019, 09:37 PM
smt6 smt6 is offline
Are they willing to give factory tours on request? I’m local, and a potential customer and wouldn’t mind checking it out.
