Old 02-24-2019, 04:35 PM
FinnFlyer FinnFlyer is offline
Default Drilling welded stuff
One of previous builders had drilled the pivot and push tube holes in the elevator horn (Wd-405R weldment) 1/8 to 3/16" off. So I figured I'd just weld them shut and drill new holes in the proper positions.
Easy enough to weld them shut with oxy/acetylene Henrob torch.
But I'm having a heck of a time drilling the new holes. Dulls my bits without making any real progress.
Is it just because I have crappy bits or is that a common problem?
I'm thinking about ordering carbide bits. How many pounds of pressure do I need to apply on 1/16" bit? 3/32" bit? 1/8" bit? 3/16" bit?
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 02-24-2019, 05:03 PM
JonJay's Avatar
JonJay JonJay is offline
It should drill just like it did to start with. It is possible that you didn’t have your torch set for a neutral or non carborizing flame. Also, I am not sure but assume the steel is 4130, but unlike mild steel, it can be heat treated and hence, hardened. If you simply welded it, and let it cool in free air, it shouldn’t harden.
I do not believe Vans heat treats this part. I know many have successfully welded and redrilled these parts. However, you may wish to check the plans for material type and if there are any post fab treatment or call Vans.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-24-2019, 05:13 PM
jrs14855 jrs14855 is offline
Default drill
You have probably air hardened the part. Heat the filled area to cherry red, then very slowly back the torch away until the area is no longer red. I have good luck with the so called titanium drill bits from Lowes. I would start out with a 3/32. Some lubricant may help.
Old 02-24-2019, 05:15 PM
Originally Posted by JonJay View Post
It should drill just like it did to start with. It is possible that you didn?t have your torch set for a neutral or non carborizing flame. Also, I am not sure but assume the steel is 4130, but unlike mild steel, it can be heat treated and hence, hardened. If you simply welded it, and let it cool in free air, it shouldn?t harden.
It's 4130. No special treatment specified.
I was worried about heat spreading to the alum it's riveted to so I did squelch it with a wet rag. Would reheating it to a deep red and letting it cool naturally bring it back to it's original hardness?
Finn
Old 02-24-2019, 05:32 PM
Ted RV8 Ted RV8 is offline
Rapid cooling with a wet rag hardened it.
Old 02-24-2019, 06:01 PM
BillL BillL is offline
+1 Absolutely correct. Just heat red and let cool slowly and you will be fine. I TIGed some holes with a copper backing and it was hard as a rock!!! The cobalt drill bit would not touch it, even with lots of pressure on the drill press. After annealing, just like normal with the same bit.
Bill
RV-7
Lord Kelvin:
Old 02-24-2019, 06:14 PM
Thank you all. I'll try that tomorrow.
Finn
Old 02-24-2019, 06:18 PM
N941WR's Avatar
N941WR N941WR is offline
You can put a wet rag on the aluminum but as mentioned, when you hit it with the weldment with the rag you hardened it. This also makes the steal very brittle. By heating it and letting it cool, as described above, you will return it to its "normal" condition.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-25-2019, 12:35 PM
Default Done
I annealed it and was able to drill the holes. Still somewhat hard to drill. Either bad bits or didn't get it quite hot enough.
Finn
Old 02-25-2019, 01:54 PM
snopercod's Avatar
Default Guhring Drill Bits
I had to drill several hundred holes in some cold-rolled 304 stainless steel bars. My machinist friend turned me on to Gurhing screw machine drill bits. I bought them from www.mscdirect.com and they did an amazingly good job. I highly recommend them for drilling tough materials. $13 each, but darn well worth it. The particular ones I bought were.
Guhring - 13/64" Diam, 130? Point, Right Hand Cut, Parabolic Flute, Screw Machine Length Drill Bit - Cobalt, TiN Finish, 26mm Flute Length, 62mm OAL, Straight Shank
(2020 dues paid)
