Old 02-24-2019, 03:47 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default Problem solved!
Problem found and thanks to Levi for the nearly immediate response. The audio panel can only talk to one device at a time, and I had been playing music through the bluetooth, hence the VIRB got, in effect, a busy signal.
It was in the manual...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 02-24-2019, 03:57 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Ed,
It is unclear what you are trying to do. You will not be able to connect everything to everything at once.
The GMA 245 can connect to one device via bluetooth. You mention that your phone is paired to the GMA, which is likely why the VIRB will not pair.
I am also not sure which VIRB you have. It may be that with your G3X controlling the VIRB that your IPhone will not pair with it.
Levi
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
