Old 02-24-2019, 11:39 AM
kaweeka kaweeka is offline
Default Alternator part number
I have the 60 amp Vans alternator on my aircraft and noticed no charging the other day when I started the aircraft. Since the cowl was coming off anyway to change the oil, I took the alternator to my local NAPA store to test. I read the posts here and found the Nipondenso part number 14684. The tester said he couldn't get a full test and wanted me to make sure the part number is correct. I just want to verify the part number for the alternator if anyone happens to know what Vans sells for a 60 amp alternator.
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 02-24-2019, 01:03 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Try 14870 or 14824 at Autozone.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 02-24-2019, 04:21 PM
Thanks. 14824 did the trick. Tested at Autozone and it failed on all tests. Ordered a new not rebuilt one $114 with a lifetime warranty. I hope it's as good as the ones from Vans. I really don't know enough about the different manufacturers to know.
G3x touch
Roseville, Ca
Old 02-25-2019, 12:49 PM
Just in case anyone wants to know, the alternator can also be referenced by a 1992 Suzuki Samurai.
G3x touch
Roseville, Ca
Old 02-25-2019, 02:10 PM
wirejock's Avatar
wirejock wirejock is offline
Default Zuk Samurai
Funny, I have one pulled off my Zuk when I swapped to a GM alternator.
My other hobby is Zuks. I have three. 87 Samurai, 00 Tracker and 02 Grand Vitara
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
