Old 02-22-2019, 11:31 AM
ssturges ssturges is offline
Default FWF Adel clamps AN3 safety wired or AN3A nylon nut
I noted on the cabin heat scat tube mount Vans drawing calls out for a AN3 with a castle nut safety wired on the adel clamp. Should all FWF adel clamps be safety wired? I saw some hints that DARs could reject using nylon lock nuts? Is there a workman standard for this?
Steve
Old 02-22-2019, 11:42 AM
Raymo's Avatar
Raymo Raymo is offline
Castellated nuts generally have cotter pins installed. No need in this application but, as a general rule, go with all metal (hot) lock nuts FWF.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-22-2019, 01:35 PM
maniago's Avatar
maniago maniago is offline
Steve
Basically, nylock nuts are frowned upon in the FWF area, so consider that your over arching guidance here....
Tho not specifically mentioned, but as a corrolary, worm clamps I safety wire as well (tho Ive never seen or heard of a worm clamp come loose in any application, aviation or otherwise) ......wire running thru the slot. I dont know if its a requirement, but seems like no harm good idea, and Ive seen others do it.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 02-22-2019, 03:09 PM
RV7A Flyer's Avatar
As noted numerous times, somebody forgot to tell Lycoming that
2019 Dues paid!
Old 02-22-2019, 04:10 PM
Bicyclops Bicyclops is offline
I had the worm clamps on my exhaust pipe rear hangers come off several times until I started safety wiring them.
All my fwf nuts are all metal locknuts.
Ed Holyoke
Old 02-22-2019, 04:25 PM
maniago's Avatar
Mmmm, yeah I know. I replaced the factory nylock nut holding one of my inj line clamps with a metal one. I think the key here is Lyco may have done all the temp tests in various areas and determined it ok in places, but they know where those places are and we dont.
For the average builder who isnt up to contemplating specific situations (much less do any testing) extrapolating the use of nylock nuts anywhere FWF just isnt a defensible argument.
Sticking with "frowned upon" is an nice way to people out of the statistics column. And off the DARs "what were you thinking?" list......
Mani
N251Y (res)
Old 02-22-2019, 05:18 PM
RV7A Flyer's Avatar
Yeah, I just didn't want someone (newbie ) panicking thinking they had to go around and swap out all the Nylocks that Lycoming (or a Lyclone vendor) had installed when the engine was built. I used a lot of all-steel locknuts FWF myself, as well as the blue high-temp Adel clamps.
2019 Dues paid!
Old 02-22-2019, 05:31 PM
rvbuilder2002's Avatar
Steve
I think you have misinterpreted what the instruction is.
Where specifically are you talking about (Model, Section #)?
The only use of safety wire related to an adel clamp that I am aware of is to bridge the clamp with safety wire from both sides of a control cable to prevent the cable from ever sliding through the adel clamp.
Scott McDaniels
Hubbard, Oregon
Old 02-22-2019, 08:03 PM
Charles in SC Charles in SC is offline
Another thing to think about is the type of cushion clamp you choose to use. In the FWF area I am using steel clamps instead of aluminum.
RV 7
Old 02-27-2019, 02:28 PM
This is OP-54(exhaust system) page 4 Figure 2, the parts provided in the kit are an AN3-4 and an AN310-3 with the instructions to safety wire the scat tube clamp.
I find the FWF the safety weak point of the kit(RV9A IO320 in my case). A lot of builder improvisation is required on clearances, routing, and techniques. I see lots of places were someone could do something wrong the could compromise the safety of the airplane. Case in point almost every time a FWF image is posted on Vansairforce people point out errors.
