Old 02-22-2019, 08:32 AM
BH1166 BH1166 is offline
Default Nylon vs Metal Locknuts
During recent conditional, prop bolts and nuts were all replaced. Changed from nylon to metal locknuts. This was the only thing changed FWF. I now have vibrations that I did not have before. Only I would feel the new vibrations. I feel them in my feet and can see more "wiggle" in Ram Mount(ed) items in cockpit. Not banging around, but sure feels different to me.
QUESTION: do you think going from Nylon to Metal is enough change to make this happen, a balance change?
My setup
Lycoming O320
Bernie Warnke Almost constant speed wood 72x72 prop
Mark Landoll Harmonic Dampener
Butch
RV6A Purchased N72TX
2020 Dues Paid
Old 02-22-2019, 08:44 AM
rocketman1988 rocketman1988 is offline
Default Prop
Is the prop clocked in exactly the same position as before it was removed?
If it is off even one hole, it could make a difference...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 02-22-2019, 08:50 AM
lr172 lr172 is offline
That is my guess as well. Weight differences between nuts shouldn't make a difference unless there were meaningfull variances in individual nut weights between old and new. If the delta weight between each nut (old vs new) is the same, it should have no impact.
Is your spinner labelled. If your spinner has any type of filler or epoxy added to it, it will give different balance characteristics when installed in its two potential positions. My spinner is marked on the inside with an A and B side to be sure it goes on the same way each time.
Larry
Old 02-22-2019, 11:17 AM
scsmith scsmith is online now
First thought was to re-balance the prop.
But a hairbrained idea did flash across my mind. Could a whole bunch of elastomeric lock washers on rotating hardware add up a hint of damping?....
No, the nuts better be tight, so the nylon locking feature can't possibly feel any displacement.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-22-2019, 11:32 AM
Did you add the drag torque of the locknuts to the recommended fastening torque?
Old 02-22-2019, 11:38 AM
Raymo's Avatar
Raymo Raymo is offline
Maybe a dumb question but why do you have nuts on the back of your prop flange? There should be inserts in the flange.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-22-2019, 11:51 AM
The Continental O-470 on my 182 has locknuts on the back of the prop flange. I've never seen a Lycoming without inserts, but I have not looked at that many. Maybe some didn't use them?
Interestingly enough, the spec'ed locknuts for the C-182 prop are Nyloks.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 02-22-2019, 12:09 PM
skylor's Avatar
skylor skylor is offline
My setup
Lycoming O320
You said you performed this work during a recent condition inspection? Is it possible that the vibration isn't from the prop at all but something else that changed during the inspection? Perhaps the exhaust pipes were moved or you have a broken exhaust hanger, or maybe a baffle seal is inside out and vibrating? Also check to make sure your spinner is still running true since it was likely removed and reinstalled.
Skylor
Old 02-22-2019, 01:29 PM
maniago's Avatar
maniago maniago is offline
What about washers? Did you maybe leave one off in the change out? Eitherway, if you find nothing and it still bothers you, revert back to nylocks and see what you get.....
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 02-22-2019, 02:32 PM
Mel's Avatar
Mel Mel is offline
He never said they were on the backside of the prop flange. Using a F/P prop on an RV, the extension bolts to the prop flange. The prop bolts have nuts on the backside of the extension flange,
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
