Old 02-19-2019, 08:59 AM
krhea krhea is offline
Default Control stick wiring
I am upgrading my control stick to tosten Cs-8 and am confused about the digital input output wiring. I am adding the MGL n16-V16 radio and a CS-8 stick grip. I built a small schematic at this link:
https://www.dropbox.com/s/bp70rxmhbd...ck%20.pdf?dl=0
I just cannot wrap my head around the ptt going to audio ground at the radio and the other ptt switchs grounding to power ground. Seems like i need to take the cs-8 apart and add another wire for the ptt trigger?
Keith Rhea.
RV7
2019 dues paid.
Old 02-19-2019, 09:44 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Schematic looks like you should be using V16 pins 15 and 17, and not 14 and 17. Not certain re pin 17 Radio Recall?
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV14A (N14ZT), Ser#140195
Start 10/11/14; AWC Rcvd 7/21/21
Contribution made 12/2/20 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 02-19-2019, 10:03 AM
Default MGL control stick wiring
I added another diagram. where i am interfacing a CS-8 stick grip functions to an MGL Explorer lite with IEFIS Extender and N16 & V16 Radios.
Here is the link:https://www.dropbox.com/s/t67ktntk9x...16v16.pdf?dl=0
Keith Rhea
RV7
2019 dues paid
Old 02-19-2019, 10:28 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Originally Posted by krhea View Post
I just cannot wrap my head around the ptt going to audio ground at the radio and the other ptt switches grounding to power ground.
You only have one switch that is PTT-------Push To Talk (transmit), and IIRC, that is the trigger. It has a separate ground wire.
The other switches are for controlling various functions that you pick. These are all tied to a single ground inside the switch. Some can be used for things like radio freq flip/flop, or A/P disconnect, or XPNDR ident------these only require a grounding of a lead to activate. For things like trim, you use the grip wiring to activate a relay.
https://tostenmanufacturing.com/wp-c...eck_wiring.pdf
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-19-2019, 11:16 AM
rv7charlie rv7charlie is offline
Simple answer: don't worry about it. The PTT just takes a sense line to ground potential, and any ground will do, for that purpose. The radio itself is almost certainly grounded to the instrument panel, which is grounded to the airframe in RVs. (You can verify on your radio by checking between the radio's ground pin and the radio chassis with an ohm meter. Any reading under a few ohms means that it's tied to the chassis.)
The critical grounding issues are related to high power noise makers interfering with extremely low level signals, like audio. There's no real 'signal' involved with the PTT; it either has a DC voltage potential on that pin in the radio (no active PTT), or no DC on the pin (grounded by the PTT). Noise is not an issue here.
Charlie
Old 02-20-2019, 12:34 PM
krw5927 krw5927 is offline
Keith, what Charlie says here is exactly what I did. Been working great and noise-free for hundreds of hours.
Kurt W.
RV9A
FLYING!!!
Old 02-21-2019, 02:02 PM
I finally figured it out and tested it seems to work ok. Had to add a 12vDC to the input through a 4.7Kohm resistor.
Schematic at:https://www.dropbox.com/s/8v19mbvyfd...witch.pdf?dl=0
Keith Rhea
RV7
2019 Dues paid
