Old 02-18-2019, 06:37 PM
dbaflyer dbaflyer is offline
Default Battery box too narrow
Went to install my battery tonight and it would not fit. The left side started to slide in, but the right side would not go. Removed the battery box from FW and measured it. The right side is only 2 and 29/32nds. This is a van's battery box that was already put together. Just needed to rivet on the angle on either side. I see my only alternative to cut the right front corner, widen it to the right size and install a piece of angle on the outside of the box to hold it in place. Anyone else have this issue? Seems odd to me that the part would come undersized.
Denis Sailer - Eastern Iowa
RV9A - N649DS - 132 hours
RV-9
Old 02-18-2019, 06:41 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Does your battery have the metal shell on it??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-18-2019, 07:36 PM
The battery is from Apex and the dimension is 3 inches wide which is what it should be.
Apex APX12180 12 Volt 18ah Sealed Lead Acid Battery
RV-9
Old 02-18-2019, 11:56 PM
erich weaver's Avatar
If you are gonna hack up the box anyway, consider adding hinge material to the front corners so that when you need to remove the battery you can just pull the hinge pins and then pull the battery out the front instead of having to pull it out vertically.
Erich
Old 02-19-2019, 12:43 PM
JonJay's Avatar
JonJay JonJay is offline
Erich
Just keep in mind the battery is heavy and the box and mounts need to withstand the g forces of a less than fatal accident. Batteries bouncing around after a very hard landing could make a bad situation much worse.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-19-2019, 04:45 PM
Pretty sure a good quality hinge riveted to the battery box and the associated hinge pins can handle a rough landing with ease.
Erich
Old 02-19-2019, 05:57 PM
JonJay's Avatar
Erich
Not a rough landing, it should withstand a non fatal but severe, total the airplane, but still be survivable kind of landing. A hinge might do just fine, but I would do the engineering before I made that mod. There are very specific rules on battery mounts.
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-19-2019, 09:36 PM
Z-EDD's Avatar
Z-EDD Z-EDD is offline
I used a locally available battery and also found that it would not quite fit. In my case the problem was the radius (or lack of) at the corners. I ended up cutting away the rear of the battery box, and saving a few ounces. I then still had to space the box away from the firewall with washers.
I remember thinking at the time that the rear of that box is redundant. It just sits up against the firewall.
I must say though, if you could find a "front opening" solution, that would make removing the battery so much easier!
Ed Fleming
RV-7- Flying as of 12/23/20
Harare, Zimbabwe
Old 02-20-2019, 12:21 AM
lr172 lr172 is offline
The back is anything but redundant. Your battery is being held in with .008 or .010 SS. That is not a lot stronger than tin foil and your battery weighs 12 pounds. That fire
Larry
