If the fitting is indeed ?in the middle?, that is not good practice. The line should extend beyond the hole with the fitting on one side or another.
I like the foam plug idea but it will need to be easily removable so you can inspect the fitting. It might not be a bad idea to use a light colored foam so you can see a leaky fitting easily.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
