Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #21
Old 02-13-2019, 03:14 PM
RV7A Flyer's Avatar
Originally Posted by Pilot135pd View Post
Debe de ser de Jalisco porque no quiere perder !!!
No, understanding how a flight dynamics indicator is calibrated and used is fairly important. A statement such as was made is confusing and easily misinterpreted by someone (such as the OP) trying to understand how to set up their system.
If the AOA algorithms are looking for the lowest angle of attack, for example, and then just taking the minimum value of n values and updating the system if and only if the SAVE button is pressed, that's a lot different than what was stated.
I still say this would all be irrelevant if Dynon would simply allow inputs for flap position (even just a simple binary up/down), and then use the flap position to choose the right point on a calibration curve.
A bheil thu a' tuigsinn a-nis?
2019 Dues paid!
Old 02-13-2019, 04:21 PM
RV7A Flyer's Avatar
Another statement from Dynon Support, just FYI...
The highest AOA you demonstrate during calibration is going to be the red zone.
http://dynonavionics.com/cgi-bin/yab...1493834841/2#2
2019 Dues paid!
Old 02-13-2019, 04:43 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Si!
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 02-13-2019, 07:58 PM
GalinHdz's Avatar
Thank you for confirming what I stated back in post #18:
Originally Posted by GalinHdz View Post
It uses that value and the previous others to calculate, via some "propriatory formula", an AOA. The formula is only run after you press SAVE, which is the most conservative one in that series of stalls.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 02-13-2019, 09:31 PM
RV7A Flyer's Avatar
I'm going to guess you never wrote code to find an extrema from a sequence of user inputs.
2019 Dues paid!
Old 02-14-2019, 07:04 AM
GalinHdz's Avatar
Nope, never have. That was a task people I supervised did.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 02-14-2019, 10:29 AM
RV7A Flyer's Avatar
LOL! I see what you did there...
2019 Dues paid!
Old 06-13-2019, 11:04 PM
sglynn's Avatar
sglynn sglynn is offline
Default Dynon HDX AOA settings
So, what are the AOA Audio Settings or other process or setup to get the Dynon AOA with HDX Skyview to work correctly? Dynon Forum is closed. I have done the Calibration per the on-screen instructions. But the tones seem to be indicating only a stall warning just before stall speed. How do I get it to indicate ONSPEED? I was thinking it should start pulsing as I slow down to landing speed and then go steady sound at ONSPEED and I'm guessing that would be around 65 - 70 on my RV-7A. But all I'm getting is high pitch pulsing tones around 55 kts that go faster and faster until it stall around 48.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 06-14-2019, 10:50 AM
GalinHdz's Avatar
Sounds like it you have it working properly. The Dynon system doesn't provide an "on speed" tone. For that you need additional equipment.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 06-14-2019, 11:14 AM
sglynn's Avatar
Default Onspeed
Galin
Thanks, that explains it. So basically Dynon AOA warns of approaching stall. Got it. thanks
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
