Old 02-10-2019, 04:04 PM
simatos simatos is offline
Default nose wheel fairing question
Regarding the nose wheel bracket U-713C: How is the bracket mounted at the nose wheel bolt? Is it pressed between (under) the nose wheel nut and bolt head? or just trimmed to fit around the bolt and washers?? With the hard attach point being the Allen screw further forward on the nose wheel fork?
thx Gary
Old 02-11-2019, 03:30 AM
rzbill's Avatar
rzbill rzbill is offline
Follow the plans exactly in regards to the washer callouts on the axle. They create a gap for the slot in the bracket to slide in. After it is slid into place, the 3/8" bolt at the front is installed and tightened. There has to be a hole in the fairing to access the 3/8" bolt in the finished state.
Bill Pendergrass
ME/AE '82
