  #11
Old 02-07-2019, 07:15 AM
bobnoffs bobnoffs is offline
the casters were handy but the real pain is always filling up the drum. if it stays on the trailer it's a breeze. gravity was a thought but you get back to a relative ''ton of work'' [dinking around]. i also have looked into air pressure but a lot more complicated and we all know what a little too much pressure can do to a flat walled tank.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
9GT's Avatar
9GT 9GT is offline
Make sure you are in compliance with airport rules. There are many airports , public and private, that prohibit the storage of fuel outside of the plane in the hanger and they also prohibit fueling the plane inside the hanger.
David C.
Howell, MI
Old 02-07-2019, 07:39 AM
n816kc n816kc is offline
Default alternative fueling apparatus
a couple of guys at Coastal in Pensacola used beer kegs out of the back of their van. tapped the keg to add a Schrader valve and used a 12 volt plug in air compressor. not sure I'd recommend it, but it worked for them for many years.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 02-07-2019, 11:30 AM
abwaldal@gmail.com abwaldal@gmail.com is offline
Been looking into this for quite awhile now.
Looking all over Craigslist and here and there.
Have settled on having a 110 gallon aluminum tank built to put under the side of my cube van. Make a door in the side of the van to access the pump and hose that would be in the box of the van. build an enclosure inside van box for hose/pump. Fill hole like factory in side of van. Vent up front of box. Fill-Rite RD series pump sitting on floor of box. Anti spill rollover valve $14.00 on vent.
Tank cost $750.00
Pump from Amazon $253.00
20 foot grounded hose Amazon $42.00
Ground reel with 50 foot line. $44.00
I'm sure I will spend a bit more when done. But hey avgas ain't cheap and the difference will be made up soon.
It could cost a lot less if you bought a used transfer tank and put it in the back of your truck.
Piece of mind and no regulations to deal with. My airport does not allow fuel storage in rental hanger.
A whole lot better cause now I can get fuel to my lawn mower at home also. Ya it'll be premium but mowers like that stuff also.
My two cents worth but I'm tired of digging lead out of spark plugs and it's proven gas engines don't need lead to last a long time.
Old 02-07-2019, 09:57 PM
MConner MConner is offline
Default Boat tank
I used a 30 gallon plastic West Marine boat tank in the bed of my pick-up. Since head pressure was about the same, I used a couple of PSI from a small 5 gallon air bottle to pressurize the tank. I bonded the tank to the truck and the plane and used a water seperating filter in the air line to avoid water contamination from the motive flow air. I ran about 7K gallons of mogas through it.
I have stored the tank for years and need the hangar cleared out. Anyone in the area of SRQ need one, drop me a note.
Mark
RV-10
Bought not built
EAA 180
48X
Old 02-08-2019, 05:08 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
I hauled my flat sided 120 gal steel transfer tank back and forth to the gas station for years on a 5x8 utility trailer and filled the plane from it first with a rotary hand pump and later a 12v farm fuel pump - until the day I found out that the local farmers' co-op would deliver smallish quantities without a surcharge _and_ they carried what I was after: ethanol-free premium 91/93 octane mogas - for less than I had been paying for that unobtanium at the nearest filling station 20 miles away
A competitor's fuel tanker truck probably wouldn't be a welcome sight rolling across the tarmac at your local airport, but it works fine at a private farm strip. Except for the time he got stuck in the wet sod while I was at the office and I had to call a neighbor to come over on his tractor and pull him free last fall - still have deep ruts from that.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 04-09-2020, 04:13 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Originally Posted by mfleming View Post
I used a 12v GasBoy pump with two particulate filters and a Go/No Go water filter. This set up worked great and I successfully pumped over 17,000 gallons of auto fuel into my C-180. [/IMG]
I'm looking for filters for my 550 fuel tank, do you remember brand, model or where you bought them?
Here's the thread here on the forum: http://www.vansairforce.com/communit...07#post1421007
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 04-09-2020, 06:01 PM
FinnFlyer FinnFlyer is offline
Sorry. wrong answer.
This is related to post #15 above.
I can answer that because I have Mark's setup:
50052113
https://www.amazon.com/SeaSense-Univ.../dp/B0019LZTGE
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 04-09-2020, 06:18 PM
Pilot135pd's Avatar
No problem, I ended up buying the clear bowl Goldenrod filter and the additonal water blocker too.
