Old 04-10-2007, 11:11 AM
BillC BillC is offline
Question Aileron to fiberglass wingtip clearance?
Started working on the wingtip installation this weekend and cut the aileronn gap area of the fiberglass using the wing attach mold line as a guide. After fitting up the tip the gap between the aileron and the fiberglass tip seems large (~ 0.375") but not large when compared to Cessnas and Pipers parked outside.
Question; what have others been cutting this gap to be 0.125", 0.25", 0.375", other?? Any thoughts about making it too small or too large?
Thanks in advance!
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 04-10-2007, 11:24 AM
frankh's Avatar
frankh frankh is offline
Default I think
mine came out at about 0.25"
Frank
Old 04-10-2007, 01:31 PM
az_gila's Avatar
az_gila az_gila is offline
Smile 1/4
Thanks in advance!
The old -6 drawings (sheet 10) give a dimension here of 0.25 inch.
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-10-2007, 02:50 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default 1/8"
The gap on my 7 is 1/8" I filled the channel on the wing tip to achieve this gap.
Unfortunately, Imageshack isn't working now so I can't post a couple of pictures.
I'll try again later.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 04-10-2007, 03:25 PM
Rick6a's Avatar
Rick6a Rick6a is offline
.......what have others been cutting this gap to be 0.125", 0.25", 0.375", other?? Any thoughts about making it too small or too large?
Bill,
For the -8 project, I simply decided to set a gap that would be pleasing to MY eyes and settled upon approximately a tenth of an inch for the gap. I'm sure it will be just fine. In any event, the fiberglass can always be trimmed back later to increase the gap which in all probability will not be likely.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 04-11-2007, 02:17 AM
Camillo Camillo is offline
Bill, I just finished my tips and...I remember that plans say to leave nominal gap of 8/32''.
I achieved this simply cutting the tip trailing edge a little bit, adjusting all the tip with the wing and then final cutting to 1/4''. After that, you can install the aluminium tip. Otherwise, if installed before, you may need to file both fiberglass tip AND aluminium tip.
Remember to perfectly align the tip trailing edge with the aileron trailing edge. I guess that a misalignment will work as a little flap while flying, thus decreasing efficiency.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
