Old 04-10-2007, 08:35 AM
dick seiders dick seiders is offline
Default cowl heat barrier
Has anyone tried Aircraft Spruce's Firewall 2000 Ceramic Blanket as a cowl heat barrier to reduce/eliminate cowl paint blisters? Or can you recommend a good substitute? Comments please. Thanks.
Old 04-10-2007, 10:11 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Fiberfrax
This used to be the preferred material.....
http://www.aircraftspruce.com/catalo.../fiberfrax.php
....has it been replaced?
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-10-2007, 02:04 PM
f1rocket's Avatar
f1rocket f1rocket is offline
I tried Fiberfrax on my RV-6. I even still had the special cement you are supposed to use to glue it, left over from my Long-EZ. If you don't cover it with something, it will soak up oil and water. Not good.
I just used the roll of sticky aluminum that Van sells. I initially had some blistering on my Rocket cowl before I had it painted. Stuck that stuff on, re-painted the cowl and the problem was fixed.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 04-10-2007, 02:13 PM
Default cowl paint blisters
Fibrefax sounds problematic. The matl Van sells- how many hours of flight w/o a blister problem? When I first painted mine I did not experience any blisters for prbably 250hrs. Re painting new cowl and want to avoid a repeat of blister problem.
Old 04-10-2007, 03:01 PM
DanH's Avatar
DanH DanH is offline
Glue down Fiberfrax sheet as required with a few dots of orange high temp silicone. Visit the aircraft supply section of your local supermarket for a roll of the heavy duty aluminum foil wrap sold by Reynolds for BBQ grill use. Cut a piece that overlaps the Fiberfrax by an inch or so on all sides. Glue it down with a thin bead of orange silicone around the underside of the overlap so that the silicone is hidden. Cheap, lightweight, works great.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-10-2007, 04:07 PM
Thanks gentlemen, I will try the Fibrefrax/reynolds foil combination.
Dick RV6A
