Originally Posted by ronoc74
I found that putting mixed proseal in the freezer at -20?C reduces the setting rate almost to zero. I mixed 70g of it 10 days ago and used the last of it yesterday - it was still easily spreadable. The frozen stuff is just soft enough to dig out a lump of it, but if I need to keep the pot out for a while I put it in ice water. It's good not having to worry about the proseal going off while you're working, not wasting heaps of it and always having some ready when you get time to rivet something.
BTW, it works even better for 2-part epoxy primer - I did some spot priming with some mixed 3 months ago. It's neat to have some of that ready when you need it too.
Conor
RV-9A 90990 wings
You are right....up to a point. Before the era of outsourcing, at McDonnell-Douglas, epoxy primers and proseal were mixed daily in an area known as the "Sealer Crib" and then distributed to the various assembly departments, stored in nearby
very deep freezers till needed on the shop floor. The proseal was labeled A1/2, A4, B1/2, B2, B4 depending upon the engineering spec and/or desired cure time. In all cases, an expiration date was stamped on each tube of sealer or bottle of epoxy and this was usually less than week. I'm sure there was a good reason for the expiration date.
I too have mixed Akzo epoxy primer and frozen the unused portion to be used later. But in my experience, I found it good for up to a week or so before becoming obviously unuseable. But mine was stored in a refrigerator freezer which I suppose does not get as cold as a deep freezer.
Rick Galati RV-6A "Darla"
