  #11
Old 01-23-2019, 07:40 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Originally Posted by UnPossible View Post
There are a few rivets on the RV-10 front skins that are a real challenge to figure out how to get a bucking bar on them.
I think I have it figured out, but just in case I was looking for a longer grip pop-rivet. In this area, the rivet is going through the side skin, a fairly thick side channel, and then a small plate that ties two section together. I stuck a rivet in the hole and marked it with a sharpie... and it measured out to something like 0.016" of material to rivet all together.
I know EXACTLY the ones you're talking about. I had the same issue finding 3/32" rivets with longer stems. Here's what I did that seemed to work VERY well for me. I simply drilled out the holes for 1/8" CS4-4 rivets and installed those in the 3/32 dimples. I was AMAZED at how well they fit. They do sit very slightly proud, but then again, I find the MK-319BS sits a little proud too. It should be no problem to hide with high build primer and paint. The CS4-4 is stronger than any longer 3/32" I could find.
Try a sample CS4-4 in a 3/32" dimple on scrap to see what you think. It was more than acceptable to me and I think the results were much better than me beating up a skin with a rivet gun trying to buck a few of those awkward rivets.
Randy Vanstory
Flying RV10 - N783V
1st Flight 08/20/2020
Donation Happily Made 2020
Old 01-23-2019, 08:30 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
You could follow the above but with CherryMax rivets that are made to the the NAS1097 sizes (aka "oops rivets")
Page 11 of this catalog - http://www.cherryaerospace.com/docs/...gs/CA-1011.pdf
The final installation would be just a shade recessed which would be perfect for filing later. Genuine Aircraft Hardware sells them in packs of 10.
https://www.gen-aircraft-hardware.co...-4-03+PKG%2F10
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
