Old 09-15-2019, 02:18 PM
sglynn's Avatar
sglynn sglynn is offline
Default Rivnuts for fairings
Are rivnuts okay to use holding the transition fairings to the fuselage?
I suppose if in aluminum they are probably as strong as a platenut. Right? What about in lower cowl for nose gear transition fairing? And whether rivnut or plate nut do you need an aluminum back sheet fo holding on the fairing?
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 09-15-2019, 02:46 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I can't address the nose gear fairings, because I don't have any, but I do use rivnuts to secure my transition fairings for the main gear. No issues at all. The key with rivnuts is not to over torque them or use them in any structural capacity. I simply installed them into the fuselage skin with no backing.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 09-15-2019, 02:48 PM
rocketman1988 rocketman1988 is offline
Default ...and
There are rivet available that have anti twist wings on them for soft metals, like aluminum...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 09-15-2019, 03:20 PM
BillL BillL is offline
If you use them, use the ones with a lock tab from Spruce. I tried the serrated style from HF on a test piece and they would spin too easily. Even when crimped well. I used nut plates instead for less future pain.
Bill
RV-7
Lord Kelvin:
