01-21-2019, 04:14 PM
Originally Posted by RV10Man
My hangar is a 60' X 72' Morton building. It has a 12' tall X 50' stack door on it. I built a 16' X 32' workshop in the back corner of it with 8' ceiling. It's got 3-8' 2 bulb high output cold weather fluorescent lights in it, I like lots of light. It's insulated really well, heated and a/c'd. ....
I did that, built in a separate workshop inside the hangar, but since we got annexed into the town and the fire codes are now being enforced it gets a bit trickier with the sprinkler rules.
If I did it again I would do a separate adjacent detached building - spacing only needs to be 5 ft...
Also if you are doing a metal building make the depth an increment of the maximum main cross beam spacing - 25 ft in our no-snow area but less up North I guess. You are essentially buying the building by the pound of steel so that spacing is the most efficient.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-21-2019, 04:27 PM
The Horton Stack Door is made/built by Horton Industries in Wellington, KS, the same company that makes the Horton STOL kits. They worked with Morton to get the header for the door just right. It's been up for 22 years now & I have no issues at all with it.
Thanks on the Morton info. On the Stack, how do you like that 1.25" tall angle bottom track on the floor? Seems like a pretty big hop over for a plane....
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
01-21-2019, 04:43 PM
Many years ago out in OK, I saw a 40+ foot one-piece door with counterweights, & loved it. I built both of mine, a 42' on the main hangar and a 30' on the 'shop side' (where the RV-4 actually lives), out of 6" irrigation tubing, covered with SunTuf polycarbonate. No motors; just swing 'em up & down by hand. I tweaked a few things on the 2nd one, and I'd tweak a few more if I ever built a 3rd, but I wouldn't want any other type of door. No wind rating at all, and you'd never get them past an actual inspector, but the older one's lived through what was left of a couple of hurricanes (~180 miles from the Gulf) and numerous tornado producing storms with winds in the 50-70 mph range.
I built & erected the smaller one totally alone, and had the help of a high schooler on the 2nd. (edit: gin pole on a tractor to erect it; a borrowed scissor lift made attaching the counterweight booms a lot easier.)
Rivets & gussets on the 1st, like a proper a/c door. Metal roofing screws on the 2nd; a lot faster & ended up being stronger.
Charlie
01-21-2019, 04:57 PM
No, you have a U channel embedded in the concrete so the bottom track is flush with the floor. No problem moving planes.
I've seen a few hangars with the bottom track raised like you say and it seems the biggest hazard is people tripping...
As a separate item the lexan panels of the Horton door give lots of light into the hangar if you don't need to insulate them.
Gil Alexander
01-21-2019, 05:12 PM
Yeah I get it Gil, thats why I asked - Stack Doors doesnt provide the embedded track with their product - thats an "other supplier" item. They dont even list who the other supplier might be. Generally it seems odd to me, but I dont know anything about these doors so wanted to get RV10mans take - maybe its a non-issue.....
Mani
N251Y (res)
01-21-2019, 05:41 PM
Your concrete slab guy needs to coordinate the installation. The dimensions are called out in the Horton instructions. It is made of standard steel materials.
http://www.hortonstackdoor.com/tech_track.htm
In my case a local welding shop made it in 3 pieces with plates that bolted them together end to end. The concrete slab guys did the rest including a 3 foot apron with a gentle slope away from the door.
I like the fact I don't need an entry door, I just open the middle stack.
Gil Alexander
VAF Moderator / Line Boy
My contractor just had a local welder fab up the track for our Horton Stack Door and then embedded it in the slab when it was poured. Worked out great, and it was an easy thing to do locally.
I also endorse the idea of a separate workshop space - last year we added a 56x30 wood-framed shop (with a 9?x30? single-panel Schweitzer door to move planes in and out) to our 50x60 main hangar. Ee have a large passageway opening between the two spaces with a strip-door to keep the heat in teh shop in winter.
As was mentioned before, the universal building code (if it applies in your area) will require sprinklers if you have more than 5,000 sqft under one roof.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-21-2019, 05:48 PM
ooooooooooooooh, I see. My bad. I read it that the entire lower track AND rollers mechanism etc etc was up to someone else to create, but I see that its just the channel and the angle iron. Thats cake - I'm my own local welding shop......
Mani
N251Y (res)
01-21-2019, 06:09 PM
Maybe less... because our airpark doesn't have fire hydrants that flow to the standards the local inspectors use 1,500 ft as a number.
The do allow a more residential system of water only and plastic piping.
The couple of local 5,000+ hangars needed more than sprinklers, they had to have heat resistant coating on the steel supports.
Gil Alexander
01-21-2019, 06:16 PM
I built my own bottom track. I used 6" channel iron, welded 1 1/2" angle iron inside of it, then built an "A" frame under it. I think it's 12" tall, then dug a ditch across the door opening (50') and set the frame down in that so the bottom track is flush with the concrete.
My brother & I hung the top door track, set up the door, centered it and lag screwed it to the building in less than 2 hours. The door hole is 50'. With the door open, I have 46' 10" clear span. The building walls are 14' high.
I just noticed Paul's comment about the sprinkle code......my hangar is 4320 sq ft. under one roof with no poles in the center. It's a truss roof, 22' 8" to the peak from the floor.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
