Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 01-21-2019, 10:20 AM
rdrcrmatt rdrcrmatt is offline
Or, for simulating partial panel, just cover up the PFD, Navigator, etc and let your safety pilot have full instrumentation.
Matt
CFI / RV-10
Old 01-21-2019, 01:13 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Talking My avionics master(s)
Control the avionics buss, but each pc. of equipment in the plane has a pullable circuit breaker --- in the case of the 650/430 each requires more than one breaker (nav, com, cdi).
The breakers make if very easy to trouble shoot or isolate. I know some folks try to minimize the number of breakers --- I pretty well maximized mine.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 01-21-2019, 08:48 PM
Bavafa Bavafa is offline
Ron
True but some of the avionics has redundant power lead and unless one has both power leads thru CB this is not easily accomplished. In my case the aux TCW feed the second lead and the passthru wires will keep the equipment energized even if I switch its master off. I am planning on putting a relay on TCW so I can shut all power to the TCW battery with one toggle switch
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-15-2019, 12:56 PM
snoop9erdog snoop9erdog is offline
Bavafa,
Why not just eliminate the pass thru function of the TCW rather than place a relay? Or would it have been better to wire like that (eliminate passthru) in the first place? Asking because I'm finalizing my wiring with the TCW IBBS and wondering what the real value of the passthru is if the IBBS is a last resort backup power in a complete main buss electrical failure.
Upon startup you have the IBBS switch on to test the IBBS backup system and ensure that it is functioning.....with the passthru, how do you know you are testing only the independent IBBS system??
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 05-15-2019, 03:11 PM
supik supik is offline
Originally Posted by snoop9erdog View Post
Bavafa,
IBBS test: MASTER OFF, IBBS ON
PASSTHROUGH test: IBBS OFF, MASTER ON
Igor
RV-10 in progress
Build Log
Old 10-10-2019, 07:00 AM
tjyak50 tjyak50 is offline
Bavafa,
Contemplating this same thing now.
With IBBS passthru you would have to pull a GDU breaker and pull the 10A IBBS breaker to reset a GDU? Almost seems like the passthru is defeating the purpose of the GDU breaker to begin with.
Let alone, seems like a single point of haywire if the IBBS battery were to decide to make trouble?
Might S/C the passthru wires we installed.
Tom "Tj" Johnson, Owner (Cell: 602-628-2701)
Airpower Insurance, LLC (Experimental friendly*)
www.AirpowerInsurance.com
Phoenix, AZ
tj@airpowerinsurance.com
* IAR823, Based KDVT
