01-14-2019, 06:50 PM
Spark plug issue / questions RV-10
Last week I flew to lunch in the -10, and had a rough engine just after takeoff.
EFIS data showed #6 cylinder not firing on the R mag.
Pulled the plugs, top plug (R mag) had very weak spark in the bomb tester.
Replaced the plug, went flying this evening.
In flight mag check ... #6 is good on both mags, but now #5 goes cold on the L mag. Mag check on the ground is totally fine.
Seems a bit odd for a coincidence, but the engine and plugs are ~2008 vintage (Lycoming from Van's) and first flew in 2016. Stuff I've read online seems to hint that Champion had some plug issues in years past.
I haven't pulled the #5 top plug yet, but the failure mode is exactly the same.
I'm thinking of just replacing all the plugs with Tempest plugs.
What are most of you -10 guys using? The chart shows both the -38 and -40 as applicable, is there a plus / minus to either type of plug?
Thanks in advance.
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
01-15-2019, 12:23 AM
The -38 and 40 refer to heat ranges. Too hot you risk pre-ignition. Too cold, you pick up more deposits. I use -38.
How many hours on the plugs? When were they last cleaned/gapped/rotated?
01-15-2019, 05:10 AM
Super Moderator
I have found lots of failed Champion plugs from that vintage. I have been replacing them with Tempest plugs. I bet if you checked them on a resistance tester you will find they fail.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
01-15-2019, 05:26 AM
Bob-
These are -38Es
Cleaned gapped etc during the panel upgrade / annual last winter. Total 153h, probably 50 or so since annual (tach time).
Vic -
Thanks for the input. I did check resistance; the old #6 plug failed (open), and interestingly the new champion plug I replaced it with also read open on the meter, but runs fine in the engine. There seem to be varying opinions on the utility / relevance of the resistance test for champion plugs. Any thoughts on that?
Should I just stick with the 38 temp plugs? Any benefit to fine wires?
Thomas Short
01-15-2019, 09:21 AM
Fine wires will fire better, are more resistant to fouling, and, in the long run, are cheaper (since they last longer). Just don?t drop one.
01-15-2019, 05:09 PM
Super Moderator
Originally Posted by TShort
Bob-
These are -38Es
Vic -
They will still fire with high resistance, but it is eating your points in the mag. The cost of fine wires can turn some people off, and I understand that. You could also try some UREM37BY plugs. They work much better in a fouling condition.
I get you cleaned and gapped them 50 hours ago. I would honestly get rid of them.
Vic
 Vic Syracuse
