Go Back   VAF Forums > Main > Reviews
Old 01-14-2019, 03:20 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Smile EAA RV Fiberglass Workshop review
I just returned from the EAA RV Fiberglass Workshop in Las Vegas.
In short, it was an outstanding class, and well work the cost many times over. It was taught by Scott VanderVeen of Pro-Composites, and I have to say he came as close to being a perfect instructor as is humanly possible.
We did three projects: 1) A repair to simulate a damaged gear skirt, 2) A gear leg fairing from scratch, and 3) The fuselage to windscreen fairing. Unbelievably, we completed all three projects in the 2-day class, with time to spare!
We also got first-hand experience making and using "poor man's pre-preg", which is a great skill to have.
Typically about every hour, I would realize and comment that the previous hour alone was worth the price of the class. And that kept repeating for almost all of the class. The second of these "aha" moments occurred when he demonstrated the difference of how BID fiberglass cloth conforms differently on a double compound curve when cut on the bias, instead of across the roll. Like night and day!
The prospect of trying and failing at the fuselage/windscreen fairing had me plenty worried, and now I am confident in doing it. Since I was unable to take my windscreen project home on the flight back, I volunteered it to be "tested to destruction" as a real-life t-peel test. The results were very impressive, and I feel his alternative to the Vans suggested method of "scuff then 8 layers of glass on aluminum" is far easier and effective.
Since the EAA doesn't do a stellar job of advertising some of these workshops, I felt it best to put this review here. If you are anything short of a fiberglass expert, I strongly recommend this workshop to everyone.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 01-14-2019, 03:33 PM
Stockmanreef Stockmanreef is offline
I totally agree. My wife and I took the class in Oshkosh this past summer. I have been a slacker and have not done the canopy yet. But I plan to use Scott's method. I hope to do the canopy in the next few weeks.
We also got a free back stage tour of the Oshkosh museum. Pretty cool
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 01-14-2019, 05:59 PM
goatflieg's Avatar
goatflieg goatflieg is offline
Agreed. I took the class in December 2018; very beneficial. For an in-depth review, see my blogspot entry for that month; link in my signature below.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 01-14-2019, 08:41 PM
rv9builder rv9builder is offline
How is Scott's VanderVeen's method different from Van's method?
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 01-14-2019, 11:57 PM
cdeerinck's Avatar
Default In short
This is an incredibly brief summary, so don't get me on the details. His full description is 38 steps with pictures.
Vans:
- Scuff the aluminum and plexi with 80 grit
- Cut and lay 8 layers of glass, increasing width with each layer, measure and sand to a profile curve with each layer
Scotts:
- Scuff the aluminum with 200 grit, and plexi with 80 grit.
- Apply a fillet of filler paste
- Apply a skim coat of structural adhesive, and a two-layer poor man's prepreg
- Apply a filler layer of Aeropoxy light
- Apply another two-layer poor man's prepreg
The second sounds like more work but is actually very easy and far less work.
So two primary differences. 4 layers instead of 8, with a filler core (which is arguably stronger), and the adhesive gives a much better bond that glass on aluminum alone.
~Chuck
DG-800S Sailplane
84CX Reserved
Old 01-15-2019, 12:53 AM
mturnerb mturnerb is offline
Vans:
Scotts:
What is "poor man's prepreg"?
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 01-15-2019, 04:51 AM
BrianDC's Avatar
BrianDC BrianDC is offline
Put glass on a piece of plastic and apply epoxy. Put another piece of plastic over and spread epoxy through the glass using a squeegee. Glass is now impregnated with epoxy and can be cut with the plastic on both sides. To apply just remove plastic.
But honestly take one of the classes. I did the fiberglass (non rv) class with Scott. It was also really good.
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - Done (for now)
Fuselage - Done (for now)
Finish Kit - in progress
RV10builder.com
KVKX / KHEF
Old 01-15-2019, 06:09 AM
Understood - I suspected that what what you were referring to. I'd take the class but now I'm so far down the road it doesn't make sense. The videos on the RV-14 support page were very helpful on the canopy work (and included the "poor mans prepreg") but retrospectively I would have benefited from the class.
Turner Billingsley
Old 01-15-2019, 06:19 AM
BillL BillL is offline
Did someone do it the Vans way and compare the peel strength?
Bill
RV-7
Lord Kelvin:
DanH's Avatar
DanH DanH is offline
..... and the adhesive gives a much better bond that glass on aluminum alone.
Which adhesive does Scott like?
Third, fourth, fifth photos:
http://www.vansairforce.com/communit...4&postcount=68
Dan Horton
RV-8 SS
Barrett IO-390
