Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 01-14-2019, 07:05 AM
goatflieg's Avatar
goatflieg goatflieg is offline
Default Jihostroj governor lever/rear case cover clocking?
While I wait for a return call from Whirl Wind, I thought I'd ask here. My governor is installed on the rear of my Superior I0-360. With assistance here and elsewhere, I got the Van's cable bracket modified and installed, and the governor installed on the engine. Also noted the cable rod end bearing bolt issue and have a solution for that. But as assembled (and safety wired), it's impossible to attach the cable rod end bearing to the actuator lever. I wasted an entire day trying to design and fabricate a lever adaptor that I could bolt to the lever; checking clearances and geometry; doing machine shop milling on aluminum stock caveman-style with files and hacksaws, etc. Came back here and did more research, looking for photos of installations. In a previous thread (Jihostroj governor cable bracket??) I examined photos and noticed that other builder's governors are clocked slightly differently than mine. From that I can surmise that all I have to do is cut the safety wire, loosen the six screws and rotate the rear case cover counterclockwise to get the lever in the right place. Is that correct? Other governors have external slots for the case screws that allow this; the Jihostroj does not... but it has to be possible because other builder's photos show the rear case to be clocked differently than mine:
Nowhere in the Whirl Wind instructions or Jihostroj documentation is this addressed, which surprises me. I found information on other threads that suggest it can be done, but those were on different governors. I don't want to mess with the way the unit was assembled until I'm sure it's ok. Any additional input would be appreciated.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 01-14-2019, 07:28 AM
j-red j-red is offline
You're correct. It was in the Vans firewall forward instruction packet, or the instructions that came with the bracket itself. Loosen, but DO NOT REMOVE the six screws and you can rotate the center section. I recall taking the arm off too, but can't remember exactly why I did that, now that I think about it...
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 01-14-2019, 07:37 AM
goatflieg's Avatar
Confirmed by Ron at Whirl Wind. Thanks to all. Don't know how I missed it in the FWF instructions... but not the first time I've done that, either.
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Old 01-14-2019, 08:27 AM
goatflieg's Avatar
Went back and checked, and now I know how I missed it. The FWF instructions mentioned the MT governor, and also referred to their installation instructions, so I tuned it out. I mentioned to Whirl Wind that they might want to include that point in their installation instructions. Since the Jihostroj governor comes safety-wired and there are no obvious adjustment slots, it's a relatively easy thing for a first-time builder to miss. That's my story, and I'm sticking to it. As Mythbusters would say: PLAUSIBLE.
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
