  #21
Old 01-30-2019, 05:18 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by iamtheari View Post
Just saw your post today. Thanks for posting it. What is odd to me is to see planes with the IBBS switch located in such a place on the panel that it is not a smooth flow to turn that on as step 1 in the before engine start checklist, as it seems it ought to be.
See post #5...
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-27-2019, 05:48 PM
tjyak50 tjyak50 is offline
I have occasionally wondered if there is any point in using the IBBS to also power the Standby Alternator reg and field (in parallel, or maybe by some diode or bootstrap switch function).
Probably overthinking options (it?s 115f in Phoenix so I left the hangar to muse wiring).
Could there ever be a case where some independent means of kicking on an alternator might be useful? Sorta rare I suppose
Tom "Tj" Johnson, Owner (Cell: 602-628-2701)
Airpower Insurance, LLC (Experimental friendly*)
www.AirpowerInsurance.com
Phoenix, AZ
tj@airpowerinsurance.com
* IAR823, Based KDVT
Old 07-28-2019, 02:35 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Rare event
Yes, this might be helpful under some very rare circumstances, like main battery failure (wiring problem?) and then during troubleshooting you somehow stop the alternator completely and it needs a bit of juice to get started again. IFR guys might want to consider this scenario during their wiring design phase since a black cockpit on a dark and stormy night is not a fun place to be.
Mickey Coggins
http://rv8.ch
"Hello, world!"
