Old 01-11-2019, 07:00 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Fuel Pump Lubricant in Service Instruction 1059E
Reviewing the Lycoming Service Instruction 1059E while learning what goes into replacing my fuel pump, I see where they recommend to put the following choice of lubricants on the pump arm prior to installation:
1. Castrol Contractors Special NLGI #1
2. Lubri-bond (A)?..fulfills MIL-L-23398 Spec.
3. Tex MOLYTEX EP 0
I cant find any of these products on the Internet. Can anyone help me locate a source for any of these lubricants?
As an aside, Service Instruction 1484C also says to use Loctite 569 on the threads.
Old 01-11-2019, 07:52 AM
lr172 lr172 is offline
just put some engine assembly lube, like lubriplate, on the contact area of the arm. If you don't have that, a dab of lithium grease will do.
Larry
Old 01-11-2019, 08:35 AM
chrisbryanolsen chrisbryanolsen is offline
Default Not Cheap
SkyGeek has a lot of these type of more obscure items, but not cheap:
Lubri-Bond
Chris Olsen
Chile Flight
N2ZK RV-4 @ KAEG
Dues Paid Nov. 2019
Old 01-11-2019, 09:10 AM
RV7 To Go RV7 To Go is offline
Default Lube
I just use cam lube which you can get at most auto parts stores at a reasonable price and quantity. It is very sticky so it won't run off before first start and is designed for corrosion protection as well as extreme pressure.
Al
Old 01-11-2019, 10:13 AM
blueflyer's Avatar
Dang, that's it Chris. Thanks. It even calls out the MIL SPEC in the description. Maybe some others will chime in who know of a cheaper source. I wont waste too much time waiting/looking considering I just spent $40 on a small bottle of Loctite 569! It makes me feel better to know I used what Lycoming called out in their documentation even if it costs me a little more money.
Lubri-Bond
