Old 04-07-2007, 03:07 PM
prkaye prkaye is offline
Default When does tank get permanently attached
The Orndoff video suggested not to put too many screws in when fitting the tank since it apparently has to come off prior to assembly anyway.
So we have to re-attach the tank with all the wing skins in-place? To put the screws through the spar to the Z-brackets, is this done through those access holes? Seems like this will be a pain...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-07-2007, 03:12 PM
N941WR's Avatar
N941WR N941WR is offline
Phil,
I don't know why they tell you that but I think you can bolt and screw them on now.
Mine were in place before I riveted the bottom skins on and to tell you the truth, after they were built, I found no reason to to remove them again.
When installing them, I found it easier to bolt the Z-brackets in place, then come back and put the screws in.
Good luck.
Updated thoughts:
When the wings were on for test fitting, I marked the fuel and vent lines for length. After removing the wings, I cut and flaired both and I sure hope they fit.
One option I saw and thought, "If I do this again...", was to put bulkhead fittings on the side of the fuselage for both the vent and fuel lines. Then I could have a short section of flex line made to go from the fuselage to the tanks. Easy to install, no worries, etc. Other than the extra fitting, of course.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-07-2007, 03:24 PM
newtech's Avatar
newtech newtech is offline
Interesting that this should come up today. I have my wings mounted and am running the vent lines and fuel lines into the fuselage. The plans tell you to do this prior to removing the wings. Well, running the fuel lines through the side and through the 7A landing gear weldments was a real pain. To make it easier, I removed the tanks; and,yes you remove the AN3 bolts through the access panels. I found it easier to get to all of the bolts with the aileron pushrods removed. I will be painting the tanks separately so they had to come off sooner or later.
Steve Eberhart
RV-7A, O-360-A1A, Catto 3 blade and who knows what else will find its way onto the plane
Old 10-17-2007, 09:55 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Question should I attach tanks prior to wing close?
I'm getting ready to close my wings and I was wondering if I should attach the tanks permanently now. I have all the bolts / screws installed snugly, but not torqued. It would be so easy to torque them (and put on torque seal) with the bottom skins off.
Do the tanks have to come off for wing mating (looks like Dan C. mated the wings with tanks on)? What about painting?
I'm leaning towards installing them now, but the manual kind of implies that the tanks may have to come off later.
Thanks for any help,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 10-17-2007, 10:12 PM
Ironflight's Avatar
VAF Moderator / Line Boy
My QB wings came with the tanks attached, and I have never removed them.....but I ID check the torques on all the bolts as Van's instructs!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-18-2007, 06:25 AM
N941WR's Avatar
Dave,
Finish bolting, torqueing, and torque sealing those tanks. There is no reason to remove them again, unless there is a leak.
Bill R.
SC86 - Easley, SC
Old 10-18-2007, 01:21 PM
Thanks to all - I'll be a boltin' tonight (inbetween long deburring sessions...)
Marion IA
