Old 01-09-2019, 06:18 AM
dmat dmat is offline
Default Show me your AFP Boost Pump mounts
I did a few searches but came up short on good pictures. I was planning on using two padded hose clamps but wantes to to how everyone else has done it on a 6.
D
- RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
- RV6: N130PJ ---SOLD
Donations Paid- Thank you VAF!
Old 01-09-2019, 06:46 AM
BillL BillL is offline
Default One data point
What plane is this for? On my 7, I just used the standard Vans design of direct mount into a small saddle with two hose type clamps. With a passive noise suppression headset it can still be heard but only until the engine starts.
What advantage is gained by a soft mount, in automotive it is for sound/noise control? Just for consideration: it may permit movement and with aluminum tube connections it just adds to potential for fatigue, it weights something, may creep and may not stay tight.
Pix available.
Update, I was eating CROW> Vans OP21 shows some rubber channel on the ears of the cradle for the pump and the filter. I had forgotten that, and fixated on the padded hose clamps. So- Vans does have some resilience in the mount.
Here is my mount plate. I had to relocate the saddles to fit the Andair valve. They are the same axial & vertical location, but squeezed together slightly.
Bill
RV-7
Old 01-09-2019, 07:25 AM
CJ in EP CJ in EP is offline
Default Almost Standard Install in 9A with Andair Selector Switch
Here's how it turned out in mine. I used the Andair fuel selector switch instead of the Van's, and being that I have electric elevator trim I bend the flange forward of the switch (where the manual trim knob would be installed) to a 90? and tucked it into the pump housing.
Good Luck!
Chris Hrabe
Eden Prairie, MN
RV-9A
N111CT
Old 01-09-2019, 08:06 AM
how did you connect the clamp to the base? rivet?
D
Old 01-09-2019, 08:28 AM
Default It's not connected to the base
If I remember correctly, the piece of base sheet metal has cutouts and bends to "cradle" the pump assembly and filter. The band clamp goes underneath the cutouts/cradle and up and around the components. Van's supplied pieces of rubber sheet to provide cushion between the base and the components.
Chris Hrabe
Eden Prairie, MN
RV-9A
N111CT
Old 01-09-2019, 02:46 PM
Default Vans #F7115A
is the pump mount. See OP21 for the optional plans for the boost pump. Even though its drawn for the old version pump, it still works for the newer version pump too.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 01-09-2019, 04:09 PM
That is correct, I added a photo above, the cradle ears have a piece of rubber channel on which to sit the pump and filter.
Tom
Thanks, Tom, I looked at this and found it does show a rubber mount in cross section and in the materials list.
Bill
RV-7
