Old 01-08-2019, 09:09 PM
dreed dreed is offline
Thanks all!
CDN- I like the idea of swapping the com/AP head unit and will have the folks at Advanced make that change as well as moving the displays up as much as possible (I am 6'4" after all).
Sahrens- good idea for sure. I'll do that as I'll be at the hangar this weekend working on the plane.
wjb- Advanced is doing the panel for me (layout, cut, wiring, etc) as a quick panel, so should be good but thanks for the tip.
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Sitting in the paint booth, then final assembly/inspection time
2018/19/20 VAF dues paid
Old 01-08-2019, 11:00 PM
N402RH's Avatar
N402RH N402RH is offline
How about something like this:
[/url]
Rob Hickman
Advanced Flight Systems
N402RH RV-10 RV-12iS Under Construction
Old 01-09-2019, 12:07 AM
Jim Frisbie Jim Frisbie is offline
Default Panel
Where is the CO detector?
It is essential
Saved my bacon.....
Old 01-09-2019, 05:14 PM
Fhuber's Avatar
Fhuber Fhuber is offline
Hi Dan, I agree with Carl about raising the displays as high as possible. It puts them in a better place for viewing. SteinAir can make you a panel, that is taller, so it's possible to move your switches under the display. They will also cut all the openings and all the holes for mounting your equipment.
With the switches under the display, place the auto-pilot control and radio control under the cutout for your IFD 540. The rest looks great.
Frank Huber
RV-7A flying since Aug 2018
Dues paid for 2019
F Huber
RV-7A flying
2019 Dues paid
Old 01-09-2019, 07:00 PM
N402RH's Avatar
That is a taller panel.... and if you want the plug-n-play ACM-ECB "Advanced Control Module with Electronic Circuit Breakers" it is only available from us.
The ACM-ECB has a port for the remote CO detector and Garmin G5, just plug it in and you're good to go.
Rob Hickman
Old 01-09-2019, 07:09 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
As a stand alone unit, or only with the panel?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-09-2019, 07:11 PM
N402RH's Avatar
We will sell it as a package with the Harnesses and equipment.
Rob Hickman
Old 01-09-2019, 08:55 PM
Thanks Guys-
Jim- great idea on the CO, I just sent Robs team a note to see if we can squeeze it in there somewhere.
Dan Reed
Camas, WA
Old 01-09-2019, 10:53 PM
Mike S's Avatar
Senior Curmudgeon
It is essential
Saved my bacon.....
This unit hides out or the way, puts a warning in the headphones and on the efis.
Loved the one I had in the 10.
http://www.fdatasystems.com/gd-40-co-detector/
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 01-09-2019, 11:24 PM
Great! Thanks Mike. That should work and looks like it'll be hidden and talk to the Advanced EFIS and chew up little to no panel real estate
Dan Reed
Camas, WA
