Old 01-07-2019, 11:37 AM
rocketbob's Avatar
I made the big cuts first...holes for engine controls, fuel/brake lines, wires, and mounting of the oil cooler. Throttle/prop/mixture cables come thru one hole like many certified birds.
Big holes have flanges I turned out of 304 stainless bar on the lathe, which firesleeve clamps to. Used stainless screws and steel stop nuts to mount those. Insulation is sandwiched in-between the firewall and these flanges.
My Comanche is 57 years old and had the same type of material on the firewall. I learned from it to make everything removable so the insulation can be replaced.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-07-2019, 02:30 PM
Checkmate's Avatar
Checkmate Checkmate is offline
I used .005 SS Shim Stock, 1/8" FiberFrax, 3M Barrier 2000+. No wrinkled tinfoil look like the thinner stuff but some oil canning is to be expected around the areas where you attach items over it. Also a hydraulic punch works great for making nice clean round holes. Ordered everything from McMaster-Carr.
https://lh3.googleusercontent.com/0G...c=w800-h450-no
https://lh3.googleusercontent.com/VH...I=w450-h800-no
https://lh3.googleusercontent.com/YT...=w1608-h904-no
https://lh3.googleusercontent.com/99...l=w800-h450-no[/quote]
Ed
RV-9A - Down for Panel & Engine Conversion
1946 Piper J-3 Cub - Flying
VAF Donation Paid Feb. 2020
