Old 04-06-2007, 10:53 AM
prkaye prkaye is offline
Default fuel sender wire
I cut and bent my fuel sender wire, and have it fitting pretty well on average. But the wire will pivot about it's own axis inside that plastic guide on the fuel sender assembly that it passes through. Is this OK? I'm also concerned that there seems to be no way for the wire to be "locked" into position... I can simply pull it out of that plastic arm without much effort. Might it not wiggle-out during use?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-06-2007, 11:09 AM
mburch's Avatar
mburch mburch is offline
You need to put a 90 degree bend in the end that doesn't have the float on it, about a quarter inch long. This fits into the plastic wiper arm and prevents the float arm from rotating. I don't know if this is in the plans but I think it is mentioned in the instructions that come with the float senders.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 04-06-2007, 11:18 AM
Default oh :(
Oh shoot... do you know if replacement wires are available?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-06-2007, 11:39 AM
Radomir's Avatar
Radomir Radomir is offline
did you trim it too much?
that little bend that Matt mentioned is in the plans/drawing.. check it again -- you may not need a new wire..
Radomir
RV-7A sold
Old 04-06-2007, 11:43 AM
Steve Steve is offline
Default I did it, too.
The 90 degree bend is easily missed. I got a replacement arm from Stewart-Warner for FREE in about a week. It took 2 phone calls and several hand-offs but I finally got to the right man at the factory down in Mexico. I started with the phone number on the S-W instructions or box. All that was 2 years ago.
... off camera....
"Topping the list of the final 10 builders of the Cheapest RV, er, lowest cost RV....."
Steve Fabiszak
Old 04-06-2007, 11:52 AM
Yeah i cut it too short. No worries, Vans has the replacement wires in their online store
I got the bends now, and it fits snugly. I have it almost perfectly positioned in the "empty" position, but it hits the top of the tank slightly before the "full" position. This is erring on the safe-side at least. Question: for fuel gauges like Dynon's (or others), can the gauge itself be calibrated to componsate for slightly different resitances on different fuel senders? I.e. can you fill the tank and then calibrate the gauge to read "full", and do the same for an empty tank?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-06-2007, 12:08 PM
Radomir's Avatar
Yes.. you have to calibrate 'em anyways to show correct values.. this applies to all manufactures, including Dynon..
Radomir
RV-7A sold
Old 04-06-2007, 12:25 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Make 'em....
You can also make new ones out of extra hinge pin wire....you can guess how I know.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-06-2007, 12:33 PM
it'd be tough to get the curve that holds the float perfectly formed, wouldn't it?
I'd rather pay the $5 personally
Phil
RV9A (SB)
Ottawa, Canada
Old 04-06-2007, 01:47 PM
Ironflight's Avatar
It wasn't the five bucks...it was the time it was going to take (at the time, fitting wings, etc...). I figured I'd take a stab at it, and it turned out easy. Bent it it a vice by wrapping it around a socket - turned out perfect (if it hadn't, I would have bought the correct part).
Paul
Paul F. Dye
