Old 01-01-2019, 01:03 PM
pilot28906 pilot28906 is offline
Default Missing Engine Baffle Parts?
I seem to be missing several parts listed in the engine baffle kit. I have looked everywhere. Are these pieces to be fabricated? Anyone have the same problem? I also have an extra part that is not called out: CB-1005A. This is for an RV-7, IO-360M1B.
Missing Parts:
CB-1002D
CB-1003C
CB-1004B
CB-1007B
CB-701D
CB-702E
CB-705A
CB-707E
CB-710D
John Johnson
Murphy, NC
RV7
Old 01-01-2019, 02:06 PM
Jpm757 Jpm757 is offline
I used the same baffle kit, If I recall the parts you are missing are included in larger pieces of aluminum and need to be separated and fabricated. At first inspection the baffle kit seem a little mysterious, check the plans closely, you may find that everything you need is there.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 01-01-2019, 03:24 PM
Thanks Jake. The kit did have some pieces that had to be cut from other pieces, however I don't see where these other missing pieces could be cut from and there is no mention of them being made from other pieces in the instructions. However it is strange that this many pieces would be missing.
John Johnson
Murphy, NC
RV7
Old 01-01-2019, 08:19 PM
Robin8er Robin8er is offline
Just sharing this because I didn't know myself. Make sure you have inter-cylinder baffles of your engine. They don't come from Vans and I didn't even know they were a thing until a mechanic pointed it out to me. My engine was used and missing them. Fortunately the airplane hasn't flown yet otherwise it would have caused cooling issues.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
