Old 12-30-2018, 04:22 AM
bill v bill v is offline
Default tip up canopy bushing not tight in hole
instruction have you push bushing into hole in canopy frame with your rivet squeezer. I could push mine in with my fingers. asked a machinist how I could get bushing tight. He said you could tighten a hole by putting a ball over the hole and hitting it with a hammer it seems like it would open the hole but it tightens it. I did not have faith so I was very gentile but it did work amazingly well. I put the frame tab on a steel table a friend held the frame so I could place a one inch diameter steel ball bearing over the hole and taped the ball gently because I expected it not to work. but after I had to get the bushing started from the other side of the hole and use my rivet squeezer to push it in
built rv-4 started 1987 finished 1996 now building rv-7, fitting cowl
Old 12-30-2018, 09:53 AM
BillL BillL is offline
Default New bushings are easy to make.
The hole likely got drilled, not reamed, too big. That said, I just machined new bushings to fit the hole, then they have the fill diameter and length of contact. Just use white brass. 15 min on the lathe and you have new bushings.
My new bushings had offset center holes to effect final adjustments to the canopy fit as well.
Bill
RV-7
Lord Kelvin:
Old 12-30-2018, 10:16 AM
sblack sblack is offline
I've heard there are people who don't have lathes. I don't know how they live. I have 2! Might get a 3rd. people are nicer to you when they know you have one. Even nicer if you have a mill.
Scott Black
VAF dues 2020
Instagram @sblack2154
