Old 12-28-2018, 02:04 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Default Sniffer valve function
Working on FWF with my new IO-360 from Vans. Just installed the sniffer valve. When I pulled the plug to insert the valve about a cup of oil drained out. Engine is long term storage from Lycoming. Trying to figure out why there would be oil. This was the only plug in the area shown in plans. I guess I don't understand the valve's purpose. I though this valve was to drain excess fuel so I don't understand the oil.
Scott- 2020 donation
New RV-7A N579RV, only 80 hours now without 2020 fly-in destinations
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
Old 12-28-2018, 02:08 PM
flyinga flyinga is offline
Oil is most likely to be from the long term storage procedure used by Lycoming. You are correct in your understanding or the valve; it drains fuel remaining in the intake system after shutdown.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 12-28-2018, 02:13 PM
Bavafa Bavafa is offline
Jim is absolutely correct but don't be surprised to see a bit of oil mixed with fuel after each shut down. It is a drop or two at most but most engines have a bit of oil mixed with the fuel. It is a nice add-on to the engine which helps drain any fuel in the sump when the engine is shut.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-28-2018, 03:56 PM
BillL BillL is offline
Lycoming fills the cylinders with oil, it leaks pass the pistons (and out the intake valves as mentioned below). It is a horizontal engine. This is why you see guys pull the prop through radial a few times on the warbirds, to clear oil from the upside down cylinders that could result in hydraulic lock during starting. You will need to do the same before starting/spinning your engine for the first time. When you remove the exhaust port caps on the heads, or lower spark plug oil will come out of there too.
Bill
RV-7
Lord Kelvin:
Old 12-28-2018, 04:43 PM
KeithB's Avatar
KeithB KeithB is offline
I believe the oil in a cylinder comes out an open intake valve, runs down the intake pipe into the intake sump. When the plug comes out, so does the oil. It happened on my engine too - and boy is that pickling oil gooey.
During normal operation, the pressure in the fuel system bleeds off in the fuel servo and a small amount of fuel ends up in the intake sump, and drains out the sniffle valve. It has a bit of oil in the drainage, I would guess from the valve stems.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 12-28-2018, 07:14 PM
mturnerb mturnerb is offline
I had the same experience. I ended up putting a hose on the valve directed into a container. The oil continues to work its way down from the cylinders and out the valve.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 12-28-2018, 08:47 PM
Default Thanks
That answers my questions so I now know this is normal. Wish I had the previous answer last night. Valve leaked a sticky oily mess onto my front tire over night. I now have a drain line connected to a container.
Old 12-29-2018, 06:02 AM
maniago's Avatar
maniago maniago is offline
Mine is pickled as well, but havent put in a sniffle yet. But this begs the question: when in operation, should a hose be permanently connected to the sniffle so that whatever comes out doesnt drip on the inside of the cowl and stain/ruin the fiberglass over time?
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 12-29-2018, 06:54 AM
j-red j-red is offline
I installed a hose back to the back of the cowl and out. Glad I did, because I accidentally flooded the engine during the first start attempt and plenty of gas came out of there. Definitely wouldn?t want that dripping into a hot cowl area.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 12-29-2018, 06:57 AM
FWF plans for IO show a drain line going to lower firewall
