  #21
Old 12-31-2018, 10:34 AM
Saville's Avatar
Saville Saville is offline
Originally Posted by rv7charlie View Post
Try plotting the points during the loop over horizontal distance. Are they really farther apart, or just appear spread out due to the vertical component?
Well I was looking at the data points after the loop - the dip and then the rise. My speed was increasing yet the data points are getting closer together in the dive and then further apart in the climb. One would think that if my speed was increasing and the acquisition rate was constant that the spacing would increase and not decrease. So I'm surmising that the acquisition rate was not constant.
But I confess to not having figured this out yet and further plotting of the data might lead to some insight.
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 01-02-2019, 11:40 AM
spatsch spatsch is offline
Originally Posted by Saville View Post
Doesn't seem to be useful in showing a round loop.
I wouldn't rule that out quite as quickly.
I used a Dynon to log my loops and in the first configuration they looked horrible.
Well maybe my loops do look horrible but the recordings looked horrible to a point that it defied physics. I important them into R so you could easily model the dynamics.... .
So I investigated and it turned out that the accuracy of my GPS signal drifted way off when inverted and took a while to come back when in normal flight. Note it's not that I lost tracking completely (maybe that is what happens to you as you mention recording slowing down) but my accuracy just got worse.
Looking at my setup (GPS antenna on dashboard of RV-8) it seems my fuselage was blocking the GPS signal in certain parts of the loop. So I put myself a little GPS data logger together I could move around the airplane easily to find a better spot by combining a serial data logger:
https://www.sparkfun.com/products/13712 15$
with a GPS module
https://www.sparkfun.com/search/results?term=GPS
they don't have the GPS I used any more but above has lots of choices which would all work. All you have to do is to connect RX to TX and vice versa connect both boards to power, write the config file on the memory card and put it in the logger and power it up.
Turns out when I moved it on my wingtip the loops were round. So my theory above seemed to be correct.
When I upgraded my GPS to be 2020 compliant I moved the Dynon puck inside of my wingtip and haven't had an issue since... .
So you might have to just move your GPS around a bit to get round loops... .
Oliver
Oliver Spatscheck
RV-8
N-2EQ
http://www.spatscheck.com/oliver
Old 01-28-2019, 06:09 AM
Saville's Avatar
Oliver
Very helpful post.
So when you moved the Dynon puck to the wingtip, I take it that the extra wire run inside the wing does not affect antenna performance/signal?
Thanks!
Flying RV-8 N880BC
Old 01-30-2019, 08:40 AM
Saville's Avatar
If a GPS receiver antenna puck is moved out to the wingtip, does it's orientation matter? If it's mounted "upright" as if on a glare shield, I take it that being upside down doesn't affect reception?
Or should it be bolted onto the outboard rib so that it is 90 degrees rotated from where it would be on the glare shield?
Thanks!
Flying RV-8 N880BC
Old 01-30-2019, 07:42 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is online now
No. The GPS antennae on our planes don't care. Some of the military jam-resistant ones might aim lobes at individual satellites for jam resistance, but not ours. Similarly, VOR antennae don't care about orientation.
ADHRS, that's another story.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 02-02-2019, 04:32 PM
DrDrift DrDrift is offline
What about using a Pixhawk UAV autopilot for a flight data recorder? It has redundant IMU sensors, GPS, internal state estimator (AHRS) and configurable logging/telemetry.
Pixhawk hardware is about $100 for the older models.
I taught a Flight Test Engineering course last semester and mounted a Pixhawk on the tie down loop of a Cessna 210. The location wasnt great for GPS reception, but we got great airspeed data up to 170 kts.
The data is logged to an SD card and can be downloaded by removing the card or downloading through a USB cable or wireless radio. The default rate is 200Hz, which result in giant files for long flights. We have configured it for lower rates for certain tests, and to only log messages that are useful for analysis.
