Go Back   VAF Forums > Main > My RV Build Project
Old 12-22-2018, 10:23 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Salvage Project... new kit or rebuild
I have a RV4 half-built wing/emp I found for very reasonable nearby. Then I found a salvage also cheap... The wing is obvious, just finish it. The fuselage is teetering on the edge of rebuild/re-kit.
I purchased it cause it probably has enough fitting and bits and bobs to make it worth the ask.
I'd take this down to bulkheads. Straighten them all out then re-skin, maybe $2500 in aluminum. Or for $5,0000 I can buy a fuselage kit from Vans and start from scratch. I'm not sure which to do. Which way would you go and why?
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Last edited by BruceMe : 12-22-2018 at 10:30 AM. Reason: crop out person from photos
Old 12-22-2018, 10:31 AM
Larry DeCamp Larry DeCamp is offline
Default OooooHhhhh , Start Over
I think you will find the end result to be much more fulfilling than a bunch of "OK" back drilled holes, crooked shop heads cause the hole was stretched etc. You will love the results more. You are going to need a fixture no matter what, my $.02
Larry DeCamp
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 12-22-2018, 11:12 AM
DanH's Avatar
DanH DanH is offline
For $2500 difference? New kit. Less hassle, and you'll get it back in resale.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-22-2018, 11:41 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Agree with the Professor, and you will get any updated parts like firewall brackets etc.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-22-2018, 12:02 PM
rvbuilder2002's Avatar
I have rebuilt wrecked RV's.
Every time you turn around you are asking yourself why the original builder put a rivet hole there?, etc. Constantly compromising the rebuild to accommodate what was done before.
So my recommendation is reuse what you can of the old where it doesn't have a negative influence and then get a new kit to cover the rest.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 12-22-2018, 06:58 PM
Scott Hersha Scott Hersha is offline
I?m also with the Prof..... New kit is..... new. No mistakes, excellent resale value (which shouldn?t be a consideration - but is).
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 12-26-2018, 04:39 PM
BruceMe's Avatar
Thank you all... looks like kit
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 12-26-2018, 05:08 PM
N941WR's Avatar
N941WR N941WR is offline
I'm with Scott.
Even if it we're a full match hole RV-8, buying a new kit means no damage history when you get it flying again and down the road when you go to sell it.
Now that you aren't going to rebuild it, you are free to use those bits on a -7, 8, 9, or whatever.
Good luck with your build!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-26-2018, 07:32 PM
acam37's Avatar
acam37 acam37 is offline
I?m on my second RV-4. First one was a rebuild and this one I?m on now you might as well call it a rebuild. It was almost to quick build but after getting it home I wound up rebuilding or replacing nearly everything on it. Including the wing spars. I didn?t inspect it well enough so it?s my fault. Never do it again for sure. Can you salvage the good stuff like the roll bar, engine mount, gear legs, flap actuator, tail wheel, fiberglass fairings,etc? That would save a few bucks on a new kit.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 12-26-2018, 10:19 PM
Billythekid Billythekid is offline
Default recently aquired 4 fuse
bruce I sent you a pm, lets deal.
