Old 12-21-2018, 07:34 AM
dwranda dwranda is offline
Default Skybolt installation question
I have the flanges installed and it is now time to rivet the firewall receptacles. I was under the impression that skybolts were adjustable meaning that the inner part of the receptacle could move around a little after riveting until you had them right where you wanted them then lock them in place. I riveted in my first receptacle and the shop head on the rivet holds the inner part of the receptacle tight. There is no adjustment at all. In the instructions they mention a floating receptacle. Is that the kind that moves a little? Should I be concerned or just start riveting away?
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 12-21-2018, 08:25 AM
rocketman1988 rocketman1988 is offline
Default skybolt
In the skybolt kit, there are only a couple of floating receptacles. All of the others are FIXED, hence accurate placement and drilling is required.
I used the drill inserts for mine and it worked out great...no need for any floating receptacles.
If you need the floaters, contact skybolt. The floaters move...a little...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 12-21-2018, 08:29 AM
rocketbob's Avatar
Even with the fixed receptacles the cowl will move around a little bit. I would not recommend the floaters.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-21-2018, 07:33 PM
RV7 To Go RV7 To Go is offline
In my Skybolt kit I received 6 of the floating receptacles and the rest were fixed. The kit was only for the firewall The cowl split line was not included. I installed 2 floaters on each side at the bottom of the top cowl (the curved area). All along the top in between all are fixed. I used the Vans hinge on the bottom cowl sides and 6 fixed Skybolts along the bottom. This makes installing and removing the cowls easy. In the instructions it mentioned that the floaters on the side make it easier to install and remove the cowl. After talking to a few other RV builders I left a 3/8" gap between the spinner and the front of the cowl to make it easier to get the bottom cowl on and off. Seems to work ok for my 7.
Al
Old 12-21-2018, 08:23 PM
BillL BillL is offline
I wanted all the fixed that were possible to more rigidly holding the cowl. Lots of forces on that cowl.
Here is a few posts related to how I got the precision. It worked quite well until I had to remove the forward skin and it was a trial of readjustment afterward.
http://www.vansairforce.com/communit...ent#post894620
+1
Bill
RV-7
Lord Kelvin:
Old 12-21-2018, 08:49 PM
sahrens's Avatar
sahrens sahrens is offline
Default Spacing
I used this thread for spacing and used three "floating" receptacles at the curved section of the cowling.
http://www.vansairforce.com/communit...t+installation
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 12-22-2018, 08:50 PM
sjhurlbut sjhurlbut is offline
Default Floaters
I recommend floating skybolts all way around. What you have is -162 fasteners. You want the -161. One riveted you?ll have a small amount of adjustment which is required. Same price and they?ll swap them out no problems
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 12-22-2018, 09:47 PM
I've got them installed on the lower cowl and now powder coating the upper cowl flanges. Tomorrow will hopefully get the upper ones in then can start on the seam fasteners. Pretty happy with how the lower cowl ones look and fit. I've never done this before so not really sure how good it really is. Hoping when I get them in and remove my alignment spacers the cowl still fits well.
9A in progress
Dues paid Jan 2020
Old 12-23-2018, 06:40 AM
DanH's Avatar
DanH DanH is offline
With either fixed or floating receptacles, the core screws in and out for depth adjustment. There is no lateral adjustment which can be locked after installation.
No reason to be concerned if the location is accurate.
Opinions vary, but I would limit floating receptacles to locations at the corners, where when sliding the cowl on and off, the pin must enter the receptacle at an angle. The floating receptacle allows the pin to slip in easier.
I would also recommend thickening the edge of the cowl. Mine has multiple plies of glass tape there and still bows outward between fasteners when I close down the cowl exit and raise internal pressure. This might be a good place to use a few plies of carbon tape (for high stiffness) under one ply of glass tape (to isolate the carbon from the mount flange). Take a look at the outer surfaces of the cowl and the adjoining sheet metal. Shim the mount flange as needed to make them flush with each other.
Internal air pressure ranges from near zero to around 120 lbs per square foot, and in response, the cowl tries to assume a round shape. We have evenly spaced fasteners all around, except at the outlet. The result is high stress at the last fastener (or the the end of a hinge if you so choose). Save yourself some trouble later; reinforce everything in that area. I found it necessary to add a buttress at each Skybolt. Without them, the rivets were overstressed at the flange attachment.
Cowl edge thickness buildup:
It wasn't quite stiff enough:
Buttress supports for the lower Skybolts. Ignore the foam work. I was building a duct.
Dan Horton
RV-8 SS
Barrett IO-390
