Old 12-14-2018, 02:58 PM
gossend gossend is offline
Lightbulb Wing walks - a (better?) idea
There are two problems with the original wing walks: They're too small for my big feet and, the rivets wear through the black anti-skid material (unevenly and ugly-ly) There's a long thread about this by Bob Noffs in here somewhere, where flush rivets are discussed. Too much work!
So I addressed both issues as thus.
1. Wear-thru. I cut the anti-skid stuff into strips to fill in between the rivet rows. Made nice rounded corners, so they look and work great. It's been that way for three years and 400 or so hours with no visible wear or peeling at the edges. I suspect that's partly because the rivet heads take much of the abuse, while the anti-skid anti-skids!
2. Size. I ordered extra wing walk skins from Vans and trimmed them to butt against the originals, roughly doubling the useable area. Now I dont have to worry about passengers with big shoes...and I can sit my lard-..s comfortably on the walk while I'm working on the panel or just fidlin' with the Garmin, without "oil-canning" the wing skin.
Note in the picture the rivet pattern looks like there are supporting half ribs under the added skins, but there are none, of course, since I made this mod after the wings were complete and flying....and dented badly by an enthusiastic but clumsy passenger.
The unsupported double-skins are super strong and support my 200+ lbs easily.
Note also I trimmed the new skins at the rear so as to avoid drilling into the spar caps!
Just an idea....works for me
http://tinypic.com/r/eu58nk/9
http://tinypic.com/m/k9x5c2/1
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with Aeromomentum AM15-HP engine
Old 12-14-2018, 03:37 PM
jpflys1 jpflys1 is offline
Sure, With all that EAB extra horsepower you don't care about the added weight of the doublers......
Old 12-14-2018, 03:46 PM
Bingo! guilty as charged
Dick Gossen
gossend@gmail.com
Old 12-14-2018, 03:49 PM
BMC_Dave BMC_Dave is offline
Single wing-walk skin sheet? Yeah probably not.
Seems like a reasonable design to me. I wish I would have thought about patterning the grip material like that when were were replacing the skins on our PA-28, I like the way that looks.
Old 12-14-2018, 09:40 PM
RFSchaller RFSchaller is offline
The guy who painted my 12 puta nice thick rough wing walk on mine. Almost 7 years on it and I am happy.
Old 12-15-2018, 12:53 PM
Dave12 Dave12 is offline
You can order real good wing walk from a/s and they will cut it to size. Been using the whole doubled area for years with it. Still looks like new, no wear and no seam.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 12-15-2018, 02:31 PM
snopercod's Avatar
Rather than ruin the looks of my plane, I carry a piece of Non-Skid Rug Pad from Wal-Mart. I carry two, actually, because I've been known to taxi out without retrieving the pad.
(2020 dues paid)
Old 12-16-2018, 11:31 PM
rcarsey's Avatar
rcarsey rcarsey is offline
i like the rug idea..
how does wingwalk (the sticky pads from Vans or the wingwalk paint) affect the laminar airflow over the wing? does the fact that the wingwalk being located close to the leading edge in the -12 have more of a pronounced effect? if frost is bad, winkwalk should be bad too..?
obviously its use is widespread and acceptable.. but in the fuselage entry/exit videos I've seen posted here in the forum, it seems I only really need one footprint size patch of wingwalk on the -12..
Old 12-17-2018, 01:30 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Even better is a yoga mat. It's non-slip on both sides and 1/4" thick, so more substantial than rug pad. Cuts easily with scissors. I used that for years before I painted on wing walks made from clear coat with Clear Grip added.
I masked off the area for the wing walk and rolled on polyurethane clear with a foam roller and then used a restaurant salt shaker to carefully sprinkle on the Clear Grip. Works well and you can hardly see it.
Old 12-17-2018, 08:03 PM
Wow! You guys are serious about cutting drag!😁
