Old 12-11-2018, 06:53 PM
Zazoos Zazoos is offline
Default Removing really old sheet metal protective film
So my wings were built in the 90's and the sheet metal was wrapped with some white film. I am struggling with removing some of it. I have tried MEK, Acetone, Brake Clean, Goo Gone, Kerosene, Shopline JT501, and Aircraft Paint Remover. Nothing touches this stuff. I even took a 3m Scotch Brite Pad to remove the white backing to expose the adhesive layer and the solvents still will not remove it.
I can Scotch Brite it all the way but would prefer a chemical method.
Suggestions?
Thank you,
Trent Flemming
Marshall, TX
Building Zenith 750 Super Duty
RV6 - N86TF
SunDog Powered Parachute - N75372
Dues Paid 11/2021
Old 12-11-2018, 06:55 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Have you tried heat?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-11-2018, 06:58 PM
n721dp n721dp is offline
I had the same problem with the spars on my -6A.
Aircraft paint remover took it right off.
Dave Gehle, P.E.
Fayetteville, Arkansas KFYV
RV-4 (sold), RV-6A, J3-C65 (sold)
Old 12-11-2018, 07:43 PM
Yes, I have tried heating with a heat gun to approx 180 degrees.
I let Aircraft paint remover sit on it for 30 minutes. Wiped right off without phasing the adhesive film.
Trent Flemming
Marshall, TX
RV6 - N86TF
Dues Paid 11/2021
Old 12-11-2018, 07:55 PM
Muuvie Muuvie is offline
Not a RV builder (yet,) but am A&P. I use Speedy 500 on breaking up adhesives, it's like a more robust Goo-Gone. Yours may have aged to the point where it's more resistant to chemicals, but I'd bet if you soaked a rag with Speedy and let is sit (while adding more as it dries) you'll break it up eventually.
Old 12-11-2018, 10:29 PM
N804RV's Avatar
N804RV N804RV is offline
Has anyone tried a "decal eraser" from ACS for this?
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 12-11-2018, 10:53 PM
rmarshall234 rmarshall234 is offline
I had a similar situation with a plexiglass canopy that had plastic film and dried white masking tape on it. Had been there for years and years. I tried all the usual things and then hit upon this:
First clean all the dust and dirt off the film. Then lay some 2" Blue masking tape over it (or duct tape if the blue isn't aggressive enough ) and press it down really, really well. All over. Pushing any potential air pockets out. Leave a "tail" on one end that you can get a firm hold of and then RIP THE TAPE off really quickly and the old film should come off too. It worked great for me. Good luck.
Old 12-11-2018, 11:53 PM
Bicyclops Bicyclops is offline
Heat gun and a scraper made from a sharpened piece of plexi. Was still a lot of work.
Ed Holyoke
Old 12-12-2018, 06:18 PM
kentlik's Avatar
kentlik kentlik is offline
This is what I would try. I use mine an anything stickyish. Just used it on my rover to get the "Range" off to fix a dent. Although mine is solid not stepped as shown.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 12-12-2018, 06:35 PM
N941WR's Avatar
N941WR N941WR is offline
WD40 helps. That is about the only thing that stuff is good for.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
