Check carefully..
A friend of mine had the same problem on his -7A, I think they're the same. It was the nutplate you mentioned that was the problem. He was able to modify the nutplate, and install a very short bolt to mount the pump. I can see where the pump might have to be relocated in some instances. We've recently learned the hard way all Van's engine mounts are not the same!
If, in fact, it's not the nutplate, you can shim behind those two mounting points to close the gap.
Good luck!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
