01-02-2019, 12:47 PM
Originally Posted by az_gila
Does it really have to be that accessible? The FAA-required transponder checks can be done with the unit in place - the only adjustments needed are for altitude encoding and they can be done by front panel programming I bet.
You may very well be correct Gil. It just seems like every time I?ve ever had a transponder check done that the shop that did it pulled it out for some reason. Maybe I need to go to a different shop. LOL!!
Mark
01-02-2019, 01:00 PM
Originally Posted by CJ in EP
Based on the information provided by Levi a few posts ago, this is how it worked out for my install:
View from the back of the sub panel
View at the front of the sub panel
I'm pretty happy with the result, and the harness on my Stein panel reaches perfectly in this location. Thanks for the tip, Levi!
Great job Chris!!
01-02-2019, 01:07 PM
Mark
The only time the old KT76A came out of the Tiger was to check the serial number for the paperwork...
The Skyview one has it's serial number accessible from the main EFIS screen, I'm sure the Garmin is similar.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-02-2019, 01:20 PM
I?m installing the same unit in my -7 build. I don?t know the exact location that I?m going to install it yet but I think it needs to be in an area that?s readily accessible. Out of all the rest of the avionics installed, the transponder is the one piece of equipment that?ll need to be able to come out on a regular basis to get checked. I?m planning on fabricating a couple of hinged fold-down trays between the sub panel and the firewall on which to mount all of my remote mount avionics, but I think I?ll probably mount the transponder on the bottom side of one of the fold-down trays just so it?s easily accessible/removable.
Mark
Why does it need to come out? I thought it was tested in the aircraft.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
01-02-2019, 01:43 PM
Yeah, Gil was asking the same question. Maybe (hopefully) it doesn?t. Like I told Gil, it just seems like I remember mine having to come out for the shop to do their check. I?m not sure exactly why they had to remove it, but maybe it was just to verify the serial number.
Mark
01-02-2019, 02:03 PM
Behind the sub panel, or?
I chose this method not necessarily because I felt the GTX would need to be removed with any regularity, but instead because I didn't want anything mounted inaccessibly behind the sub panel. With five remote boxes, this was the only way to go.
Chris Hrabe
Eden Prairie, MN
RV-9A
Finishing Engine / Starting Panel
