Originally Posted by RogerG
Gill,
We have the Wag Aero fixtures on TA67 3000’ grass. 2 years ago we traded out the 15W E17 incandescent bulbs with LED Microwave bulbs 6000K which are equivalent to 35W Halogen. The concensous on the field is way better, brighter, whiter light, with less energy consumption, and less voltage drop due to lower wattage. Only complaint is the LED’s are more prone to failure with lightining strikes than the incandescent.
The LED’s we used are 4W 360 Lumens 6000K, E17 base, Silicone coated. You can find them here:
https://www.amazon.com/dp/B01HPHEM72...v_ov_lig_dp_it
Thanks - we'll look into those. Our manager has been buying Chinese LED ones by the box but they seem to the taller than the ones you show and don't fit well under the Wag Aero glass domes.
As far a lightning goes, it looks like we are pretty similar to your area....
https://images.theconversation.com/f...402-akeyik.png
We had a lightning detector station on our airpark for many years until Global Atmospherics Inc. of Tucson got bought out by Viasala, who made the map above. How the whole detector network works is quite interesting.
