Old 12-04-2018, 11:53 AM
romanov's Avatar
romanov romanov is offline
Question Question on wiring trimmer servo
Fellows, we have some difference on the servo scheme vs Vans drawings.
Any idea how to connect those pins?
Thanks in advance
Roman.
Blogging my RV14 here:
https://bit.ly/2PzjPzS
Old 12-04-2018, 12:01 PM
Raymo's Avatar
Raymo Raymo is offline
The gray wire in the top drawing is the same as the second white wire in the bottom schematic.
Each white wire drives the trim servo in or out. You can test using a 9 volt battery to ensure you have the correct travel direction / polarity.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 12-04-2018, 12:32 PM
romanov's Avatar
So the the connector is like that:
Code:
2 - ORN
3 - GRN
6 - BLU
5 - WHITE
4 - GREY
is it correct ?
and just curious why the notation says WHY/BLU , WHY/ORN
what does it mean?
Old 12-04-2018, 12:43 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
what does it mean?
In most cases a notation like "WHT/BLU" would reference a WHITE wire with a BLUE stripe on it.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
