Old 12-03-2018, 11:04 AM
kkmarshall kkmarshall is offline
Default Battery mart deals?
Does anyone know of any sales or coupon codes for Odyssey batteries that is currently available? I haven't found anything and it's time for a new battery.
Keith
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 12-03-2018, 11:52 AM
rv7charlie rv7charlie is offline
Default Easy; just remove the branding...
https://www.batterymart.com/p-sla-12v22.html
;-0
Of course, I'd never tell you to do as I've done for a couple of decades, and buy the best priced SLA with enough AH capacity for a/c use...
edit: I *do* look at either CCA, or source impedance (more useful, but not as often spec'd). There are some 'deep cycle' SLA models that might not crank an engine very well. But most I've seen in the 20AH+ range do fine as starting batteries, and you get additional alternator-out capacity, in the bargain.
Old 12-03-2018, 12:40 PM
Looking for 925 size for RV10. But thanks for the info.
Keith
Old 12-03-2018, 01:32 PM
That data point would have been a helpful inclusion in your initial question. :-)
Lots of options, if you have a bit of mounting flexibility.
Here's one:
https://www.apexbattery.com/intersta...UaAleVEALw_wcB
Or you could just pay for the name...
Old 12-03-2018, 07:18 PM
That one looks like a great option,thanks!
Keith
Old 12-03-2018, 09:26 PM
Be sure it'll fit your battery box; the dimensions are a bit different from the Odyssey.
Hope it works out,
Charlie
Old 12-03-2018, 09:39 PM
Yes,very close on dimensions though.
Keith
