Old 12-03-2018, 09:09 AM
bkervaski's Avatar
bkervaski bkervaski is offline
Default Baffle Seal Rip/Tear ... any way to repair?
I have a couple very minor baffle seal rips/tears from just taking the cowl off and on, is there a cement that can be used to successfully bond these tears so they don't progress?
They aren't bad enough to replace the seal .. and you have to purchase the entire seal kit, I can't just get the two small pieces that have torn.
Thanks for any advice!
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-03-2018, 09:15 AM
Ron B. Ron B. is offline
I had to replace both front seals and I had some left over from a previous build. I also had some seal material from a long time back and it had impregnated thread/ canvas in it. It's still in good shape and much stronger than what is supplied but I did not have a piece long enough.
I would really like to find more of that stuff. Anyone know if it is still available?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-03-2018, 09:36 AM
JonJay's Avatar
JonJay JonJay is offline
You can "stitch" the tear with rib lacing and a rib stitching needle. The rib lacing is wax coated and holds up very well over time. With care, it can be done to look purposeful and neat.
I also coat the stitching with RTV, rub it in with a finger and it adds a layer of protection.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-03-2018, 09:39 AM
bkervaski's Avatar
The tears are probably 1/8 inch. I'm really just trying to prevent them from getting worse over time. Not even noticeable when I push them back into place.
I wonder if some CA will do it?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-03-2018, 09:41 AM
Raymo's Avatar
Raymo Raymo is offline
You can purchase seal material from ACS but the above recommendations will work just fine. Either red or black RTV to match your seals.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 12-03-2018, 10:24 AM
DanH's Avatar
DanH DanH is offline
What seals and seal kit are we talking about here?
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-03-2018, 12:24 PM
Bill,
I used a plenum and probably have my baffle seals in my hangar I didn't use. If you want it, I will be home Sunday and will check and send it to you. Let me know if you can wait until then.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 12-03-2018, 03:49 PM
rzbill's Avatar
rzbill rzbill is offline
On original construction 750 hrs ago, I was making some compound curves in the seal fabric around the nose section of the engine. I simply lap joined the baffle fabric with gorilla snot (weatherstrip adhesive).
Still holding together fine.
Bill Pendergrass
ME/AE '82
Old 12-03-2018, 05:44 PM
bkervaski's Avatar
Thanks all.
@DanH the -14 comes with the rubber baffle seals cut to final size and chamfered. Vans only sells the entire kit, it was around $400. If I was to replace I would just need two small around the air intake.
@rockwoodrv9 Thanks for the offer! But save them for the next guy, it's not bad enough to warrant redoing them.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-03-2018, 07:42 PM
Jpm757 Jpm757 is offline
I have had good luck using a small hole punch to "stop drill" tears in the rubber gasket material.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
