11-29-2018, 09:48 AM
Looking for Hose w/o steel reinforcement
I need a 2" hose to feed the overhead console in my 10. This hose will pass relatively close (maybe 6" or less) to the magnetometer mounted up high. I am trying to find a 2" hose that does not contain steel reinforcement wire to avoid magnetic interference.
Does anyone have ideas or recommendations?
Disregard. I found some hose at Mcmaster that uses plastic support rings.
Larry
11-29-2018, 09:55 AM
Larry
Larry, if it does not need to be too flexible nor too long, then some silicone coolant or air inlet hose from HRPWORLD.com might be good for that. You could make your own, but easier to buy.
I got some by the inch, but it happens to be located close to me. Good outfit.
BTW, my 10 friend had issues and did the same, and used stainless seatbelt cables too. I will ask him and get back. My 06C trip was excellent. Inbound as a third corridor to the two ORD inbound ones that straddled 06C. I'm going 170kts and they were 210kts. Quite interesting on the traffic monitor. Sweet little airport. See you next visit.
Bill
RV-7
Lord Kelvin:
11-29-2018, 10:07 AM
Senior Curmudgeon
Why not just remove the wire from the hose ---- pretty easy to do.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-29-2018, 10:19 AM
If it's standard SCAT hose the wire spiral is the only thing keeping it in a tubular shape.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
11-29-2018, 10:44 AM
Mcmaster
McMaster has several options with plastic ribbing. Here is the part number for one:
5152K43
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
11-29-2018, 11:11 AM
I found some. Thanks for all of the input.
Larry
11-29-2018, 11:14 AM
Yea, always plenty of traffic around 06C to keep your screen full. Glad it was a good trip for you. Hopefully you brought her back on Saturday. Sunday was ugly with a lot of icing risk. I flew my son back to Mizzou on Saturday.
I thought the seat belt cables from Van's were SS. Do I have that wrong?
Larry
