Old 11-28-2018, 10:28 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default List of infrequently inspected/overhauled/replaced items?
Hi, all... now that my RV-10 is nearing 8 years and 500 hours, I'm wondering whether I'm missing any of the preventative maintenance items that are done infrequently, such as the 500-hour mag inspection and (10-year?) flexible fuel/oil hose replacements. Does anyone have a good list of these items? Similar question asked a few years ago here, but didn't see a comprehensive list. Thanks!
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 11-29-2018, 10:54 AM
Andrew Anunson Andrew Anunson is offline
Default Ten Year
Precision Airmotive recommends overhaul of their FI servo 10 years (or 2600 hours whichever comes first) after first put in to service. You could consider having their FI Servo and flow divider overhauled in a couple of years.
Old 11-29-2018, 11:14 AM
Noah's Avatar
Noah Noah is offline
Plane Power alternators require a 500 hour brush inspection.
Wobble Test required on exhaust valves in Lycoming engines at 1000 hours (if you have high chrome exhaust valve guides which newer engines now do).
5 yr ELT mandatory battery replacement and 10 yr (depending on battery chemistry) ELT remote control panel indicator battery replacement.
Those are a few that come to mind.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 11-30-2018, 07:58 PM
jpowell13 jpowell13 is offline
Default Engine driven fuel pump?
How often should engine driven fuel pumps be rebuilt or replaced? And, what about carbs?
Old 11-30-2018, 10:00 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
From Tempest -
A: Diaphragm fuel pumps should be replaced or overhauled:
1. At engine TBO or after ten years in service, whichever occurs first. Replace on condition if leaks develop or performance drops for example.
I assume it's similar for a carb. but I can't find any actual data...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-01-2018, 07:04 AM
N941WR's Avatar
N941WR N941WR is offline
The bolts that hold the engine mount and gear legs should be checked for proper torque.
Also, the Lycoming manual says to check the bolts that hold the carb/fuel servo. (I check all the engine accessory bolts. Maybe this is why my condition inspections take so long?)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-03-2018, 01:44 PM
RV7A Flyer's Avatar
My PP paperwork shows "5 years or 1000 hours", without any qualifiers like "whichever comes first".
I'm going with 1000 hours.
2019 Dues paid!
Old 12-03-2018, 01:54 PM
erich weaver's Avatar
Check the manual for recommended TBO on your prop governor if you have one
erich
Old 12-03-2018, 06:09 PM
AlexPeterson's Avatar
Originally Posted by az_gila View Post
From Tempest -
See Dan's pictures on post #5 of this thread. I think 10 years is too long for these diaphragm pumps. I recently changed mine with almost identical time/age as Dan's. Pressures were erratic, but fixed with new pump. Old pump was not leaking. I will be looking to replace in around 6 years next time. I did not take mine apart, but simply sent it back for the core charge.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
